02 Sensor Swap Information
  • bemis
    bemis
    • 696
    This Sticky was designed to address the issue of 02 sensor swapping, between Titania and Zirconia, due to engine harness or ECCS changes.
    Using the information here, one should be able to easily swap 02 sensors if they have basic reading and wiring skills.
    Here's the difference between the two sensors:
    Here's how the two different 02 sensor styles are wired up according to the Factory Service Manual:
    Here's a list of what kind of 02 sensor came with the Z31's from the factory:
    1984-1985; 1987-1989 NA: Zirconia
    1986 NA & Turbo: Titania
    1987-1989 Turbo: Titania
    The ECCS is designed to only use one type of 02 sensor, either Titania or Zirconia. No exceptions.
    1984 300ZXT
    1986 300ZX 2x2 NA2T
    2000 Porsche Boxster
    2007 Toyota Yaris
  • SATAN
    SATAN
    • 6782
    And there it is. Now use this info people. I know I will be!
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    So the titania has to have voltage sent to it.
    Is that comparison diagram out of an 87-89 since they had both?
    Terrible idea putting those wheels on…
  • Zed31
    Zed31
    • 103
    Dude, YOU RULE! You have answered the one question that has been bugging me for about two weeks. Definitely sticky this.
    1986 300ZX, Got the 85 Turbo Engine, Satan's Exhaust manifold, GT35R, Tial 44mm WG, Tial 50mm BOV, Nistune, 460cc Injectors, Treadstone Intercooler, NGK Wideband, Greddy Profec B Spec II EBC, 16 PSI and rising, heehee.
    1993 300ZX Convertible, Pearl White, Bone Stock summer car.
    1985 300ZX Turbo Wrecked (Parts car) : ( In her old days
    1984 Mitsubishi Starion \
    1987 Dodge Conquest - None of them run, LOL
    1988 Mitsubishi Starion /
  • got boost?
    got boost?
    Member
    • 77
    #5
    Is the M30 ECCS O2 sensor Titania or Zirconia?
  • bemis
    bemis
    • 696
    #6
    got boost? wrote: Is the M30 ECCS O2 sensor Titania or Zirconia?
    titania
    1984 300ZXT
    1986 300ZX 2x2 NA2T
    2007 Toyota Yaris
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    #7
    Zed31 wrote: Dude, YOU RULE! You have answered the one question that has been bugging me for about two weeks. Definitely sticky this.
    haha, its been like 6 months and i am just figuring out that I just need to run the 12 volt power from the fuel pump relay to the titania sensors heating element. :lol:
  • JustinCase
    JustinCase
    • 169
    #8
    I've been looking for this for weeks…
    But i'm having a hard time understanding the route it's listed.
    Going from 89NA to 87T o2 & ECU.
    Someone let me know if i'm getting this right:
    The late model turbo shares the same general wiring on the green and black wires. I need to relocate the yellow wire from point 115 on the ECU to grounding point 36F:
    So, I could just reroute the wire from the harness to the plenum ground instead of it going through to the ECU.
    This is how i am interpriting the FSM wiring diagram, it seems like a fairly simple swap to go from Zirconia to Titania. I've always heard this was a tedius wiring job. :-?
  • G-E
    G-E
    Junior Member
    • 6320
    #9
    someone post the 86 diagram that has the large bung titania with 3 wires
    bdg login.
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    #10
  • JustinCase
    JustinCase
    • 169
    #11
    Is there something i need to look at on the 86T diagram?
    I'm not sure what you're trying to tell me.
  • CAG8OR
    CAG8OR
    • 171
    #12
    I have some questions as well pertaining to the '86T harness. As you can see from the shcematic above the later model ('87-89) turbo cars should have a four pin connector (40F) at the O2 sensor. Mine ('86 turbo)has a three pin connector which is identical to the N/A connector (35F) which is supposed to correspond to the zirconia sensor.
    Here is the bone; I had installed an '84T JWT ECU around five years ago. When I did, I removed the titania sensor and installed the zirconia unit by swapping out the bushing in the elbow. The car ran perfect and I never thought about this until a week ago reading from here. On Sunday, I pulled the ECU and reinstalled the '86 turbo ECU and titania sensor. The bushing was seized this time and was a real PITA to remove, but I got it out after major coaxing from an impact gun. The car runs identical as before. If I was running in open loop before due to zero feedback from the O2 sensor, I should have been able to notice some sort of difference right? Why does the '86T harness not have the four pin connector? Is the '86T harness unique in this regard? If you order an O2 sensor for a '87-89 turbo car, will you get a three or four pin connector installed on it?
    2006 & 2007 Basketball National Champions! 2005, 6, & 7 Basketball SEC Champions! 2006 Football National Champions! 2006 Football SEC Champions! 2008 SEC Champions! 2008 Football National Champions! First University in history to capture three titles in a single year! I was there at all of them, and it was awesome! Go Gators!
  • CAG8OR
    CAG8OR
    • 171
    #13
    Ooops, I did not notice the '86T schematic link above. Thanks, that answers alot of questions. I still am not so sure why my car seemed to run fine with the zirconia sensor & '84T ECU without relocating the ground wire in the harness. I am also having some issues with what the FSM states about the titania sensor. It says that the ECU supplies the sensor with one volt and compares the resistance values using a comparitor. Does it supply the one volt through the same wire it measures the resistance on? This does not happen on the zirconia sensors? What is the purpose of pin 115 on the ECU? I thought this was a ground, which would make the wiring identical electrically.
  • MrwassmanNA2T
    MrwassmanNA2T
    • 2319
    #14
    The 86T's sensor makes no sense. Heater 2 wires? and signal…what?
    Or is it heater source (+) in, grounded through housing (PTC, so it automatically stays temp needs to be) and 1 volt reference in and signal out?
  • CAG8OR
    CAG8OR
    • 171
    #15
    I agree, waiting for clarification. Something is not right here.
