Need help… MAF question
NorCalZJunior Member- 24
I want to perform a MAF to MAP conversion on my '87 Z31. Anyone out there know what it would take or how to do this? I've heard that a MAP sensor is a better gauge than a MAF especially when boosted so any help would be appreciated, thanks.Black 1987 300ZX NA manual 18 inch infiniti G35 wheels
Black 1968 Chevy Camaro SS 383ci stroker
Green 1963 Willys CJ5 327ci 3 1/2 inch lift 33 inch tires -
nutsaqSenior Member- 208
so i can't just hardwire the map sensor into the MAF wires? I'd actually need to buy a whole new fuel management system, correct?Black 1987 300ZX NA manual 18 inch infiniti G35 wheels
91crxsirMember- 47
You need to buy some kind of stand alone setup. I can say if you didn't know that then you wont be able to install it yourself. -
well, i was starting my research by asking that question, but I am definitely capable of installing a system like that… I'm just coming to you guys for answers and support, not insults thank you very much.Black 1987 300ZX NA manual 18 inch infiniti G35 wheels
SATANSenior Member- 6782
The easy way would be to run a stand alone. This way you can choose between a MAP or a MAF. There is probably a way to wire one in and use all kinds of fancy electrical engineering shit, but to do it easily… No. Just go stand alone.NorCalZ wrote: well, i was starting my research by asking that question, but I am definitely capable of installing a system like that… I'm just coming to you guys for answers and support, not insults thank you very much.85 Z31 6.0 LSX turbo 766whp/792wtq
awesome… that's what I was looking for, thanks… greatly appreciatedBlack 1987 300ZX NA manual 18 inch infiniti G35 wheels
