K constant and latency with Cobra MAF
SupSay ZSenior Member- 180
whats up guys, just as an estimate, what is a ballpark figure for k constant and latency with a cobra maf using 550cc injectors? my numbers came out to 592 (0250) k and 2340 (75) latency. i thought that the k value was way off but it is what automatically came up. any ideas? thanx a lot guys..
alex
P.S. this was already posted on the nistune forum and matt said this would happen, meaning nothing i did wrong.Must Go Faster, Faster Untill The Thrill Of Speed Overcomes The Fear Of Death. -
1SIKZ31Senior Member- 1236
TRY using a K-Constant starting out at around 300.
I have like 283K on my car though its an ENTIRELY different set-up it gives you an idea.
You need to start ur Z with a wideband and just Tune the car with it.
Heres a HELPFUL PDF from nistune on how to tune the car (Including adjusting the K Value)
http://www.plmsdevelopments.com/files/n … basics.pdf
Read it :--)1SIKZ31 -86 SlickTop- R.I.P. 03/01/10 … Parted out :-(
