External Fuel pump and fuel sump.
onefast87Senior Member- 696
Hey guys, im in the middle of redoing my entire fuel system for my LS swap. Ive got some -8AN for the feed and a -6AN for return. I also have a weld on sump for the tank.
Was hoping you guys could post up some pictures of your sumps and external pumps for some extra motivation.
And GO!!http://www.youtube.com/user/onefast87 -
88sinZSenior Member- 2019
I think the greatest flaw of the fuel tank is no slosh baffles. In with that argument is the cause for a baffled fuel cell.
It does have a solid up swept area on the rear that should fit some universal sump pans. Was about to pan it before figuring out an in-tank solution, it doesn't like to be under 1/4 tank though. -
Thanks for the replies, this place doesn't seem as busy as it used to be. I guess its just easier to do it then to come online and ask. I will post up my setup when I complete the fuel system.http://www.youtube.com/user/onefast87 -
defiantly not, both a blessing and a curse helping weed out the discourse.
Sometimes you just gotta cut into the guts of it. -
I got most of it in the car, but before I finalize it, im wondering for those who have put in stainless fuel lines in their car, where are you running the lines? Seems a little bit tight over the subframe, wich is where my issue is. I ran the lines pretty much where the factory lines were. Anyone have any pics to share??http://www.youtube.com/user/onefast87
