Can you run bigger injectors with an adjustable fuel pressure regulator on stock ecu?
Charles84AEJunior Member- 9
I have an 84T with a Jim Wolf ecu upgrade, T3/T4 turbo, intercooler, Schneider stage 3 cams, 12lbs of boost and 3" exhaust with Walbro fuel pump.I'm running a little lean. Any good brand of adjustable fuel pressure regulator? Thanks. -
BLITZERKING1Member- 74
Fuel lab, Aeromotive. It should work with a stock ECUOriginally posted by Charles84AE View PostI have an 84T with a Jim Wolf ecu upgrade, T3/T4 turbo, intercooler, Schneider stage 3 cams, 12lbs of boost and 3" exhaust with Walbro fuel pump.I'm running a little lean. Any good brand of adjustable fuel pressure regulator? Thanks.
