Nistune Low impedence 550cc RX7 injectors question
 BLITZERKING1Member BLITZERKING1Member- 74
 Nistune Low impedence 550cc RX7 injectors questionSo I have an 87 NA auto ECU that has Nistune installed on it and it has an 88 turbo ROM on it. Can I run my low impedence RX7 injectors on it without dropping resistors? I know the 87 NA ECU takes low impedence injectors but an 88 turbo uses high impedence. My car is an 84 turbo
 shromySenior Member shromySenior Member- 2189
 your correct, i must have read wrong. peak and hold aka low ohm drivers can run both low and high impedance.Hmmm, Whats next?
 84ZXT
