Injector Identification
Gokussj5okazuJunior Member- 1
Hey everyone, I need some help identifying a set of injectors. A customer of the shop that I work for brought in their 86 Z31 with a turbo kit that was cobbled together by someone they knew. The person says they're 550cc injectors, but now that I'm to the tuning stage I have some serious doubts.
The injectors look exactly like stock style ones, with the end barb and aluminum base. The tops, however, are completely dark blue. Any idea what size these could be? I can measure the impedance tomorrow, but otherwise I have no info about them. Thanks -
JSMSenior Member- 279
You would likely need to send thm off to have them tested and flowed unless you post a pic and someone can ID them to know for sure.
