Base ignition map (rpm/Map)
RoyHSenior Member- 113
Hi,
Back from being away for some years. Last year i dug out my 88 z31 turbo and (86 engine) and modded it a bit. The build topic will follow later
In short i'm looking for an ignition base map based on rpm vs MAP instead of rpm vs MAF (Original nissan / nistune). I changed the engine management to Autronic so its using MAP instead of MAF.
An excel or Just a picture would be fine.. I Just need the numbers.
Engine is stock except for the following
- autronic ecu
- MAP sensor instead of MAF
- holset hx35 turbo
- rx7 550cc injectors
- vw vr6 dis ignition system.
Thanks
Rick88ssSenior Member- 2433
no response? Did you get it figured out? maybe some people that are running mega or microsquirt can share their timing mapShiro #443
Nope, I wrote something myself and it runs nice and smooth. Well at least at idle and low revs. Still need to finish allot on the car before I can drive and tune it a bit more
