ECU PINS DIFFERENCES/SIMILIARITIES
  • ECU PINS DIFFERENCES/SIMILIARITIES
    Sooo, I am searching, looking around for the information I'll be needing in order to plug-in and use the '88n/a 5 speed federal ecu on the '87T(5speed federal) build I am doing.
    *I am not having very good luck locating the ecu pin outs and descriptions for the various years(84-89) and models(n/a, turbo, calif, federal).
    **Once upon a time, I had saved off from z31.com, information that showed the ecu pins and functions for various years...it is currently lost.(If I locate it, I'll upload it to this thread)
    ***Has this information been covered, and I'm just missing it?
    thanx,
    Dan
    *EDITED*
    ~Here's all that I have thus far:
    Subject: 84 NA ECCS Pinout
    Subject: 84 normally aspirated computer pin out
    84NA ECCS Connector
    pin/wire color/destination
    1 X
    2 L..........FICD/Idle up Solonoid
    3 L..........Ign Coil, Pwr Trans
    4 L/W.....EGR Control Solenoid
    5 G/B......Pwr Trans
    6 R..........EFI Relay
    7 X
    8 G/Y.....CAS (sheilded)
    9 Y..........Ig Switch, G/Y to Pressure Reg Con Module
    10 X
    11 G.......Unused Connector
    12 R/W. AFM
    13 X
    14 X
    15 Y........Fuel Temp Sensor
    16 B........Air Reg
    17 G/B....CAS (sheilded)
    18 P/L.....TVS
    21 X
    22 Y/G.....A/C System, Headlamp Switch
    23 Y/G.....Pres Reg Con Modulator, CHTS
    24 B.........Oxygen Sensor (sheilded)
    25 L/G......TVS
    26 B..........CHTS, AFM
    27 B/W.....Pin #35
    28 B..........Pin #36
    29 X
    30 Y/G.....AFM
    31 B.........AFM (sheilded)
    32 X
    33 X
    34 G/W...Ig Coil, 15A Fuse in Fuse Block
    35 B/W...AFM (sheilded), FICD/Idle up, EGR Con Soleniod, CAS (sheilded), L/R to Pres Con Reg Solenoid, G to Pres Reg Con Mod
    36 B........Bonding Wire for Sheilding, CAS (sheilded), Pressure Reg Con Mod, Unused Connector
    101 G.......Injector #1
    102 G/B...Injector #3
    103 G/L...Injector #5
    104 G/Y...Injector #2
    105 G/R...Injector #4
    106 G/W..Injector #6
    107 B.......Ground, FICD Soleniod Valve; Pins #109, 112, 113
    108 B.......Fuel Pump Relay (sheilded), Fuel Pump (sheilded)
    109 B.......Same as #107
    110 X
    111 X
    112 B.......Same as #107
    113 B.......Same as #107
    114 R.......Fusible Link, Injectors
    115 Y.......Pres Reg Con Modulator, Oxygen Sensor
    Beckum......5/3/98
    84T ECCS Connector
    1 X
    2 L..........AAC
    7 X
    10 X
    12 R/W. AFM
    13 X
    14 X
    16 B........Air Reg
    18 P/L.....TVS
    21 W........Detonation Sensor (sheilded)
    22 Y/G.....A/C Relay, Headlamp Switch
    25 L/G.....TVS
    27 B/W.....Pin #35
    29 PU.......Combo Meter (Vehicle Speed Sensor)
    30 Y/G.....AFM
    32 X
    33 X
    35 B/W...AFM (sheilded), AAC, EGR Con Soleniod, CAS (sheilded)
    102 G/B...Injector #2
    103 G/L...Injector #3
    104 G/Y...Injector #4
    105 G/R...Injector #5
    110 X
    111 X
    Beck......3/15/98
    ****DO NOT KNOW IF THIS IS N/A OR T FOR THE 1986****
    Subject: 86 computer pin out
    86 ECCS Connector
    1 R..........-not used-
    2 L..........AAC valve(T), Idle-up solenoid(NA)
    4 L/W........EGR Control Solenoid
    5 G/B........Pwr Transistor
    7 SB.........To Combination Meter (digital type)
    8 G/Y........CAS (shielded)
    9 Y..........Ign Switch
    10 BR........Neutral Switch(M) or Inhibitor Switch(A)
    11 G.........-not used-
    12 R/W.. ....AFM
    13 -no pin-
    14 Y/G.......AIV Solenoid
    15 Y.........Fuel Temp Sensor
    16 B.........Air Reg
    17 G/B.......CAS (shielded)
    18 P/L.......Throttle Valve Switch
    21 W.........Detonation Sensor (shielded) (T)
    22 Y/G.......to A/C system(NA),pwr steering sw (NA),
    .....FICD solenoid valve(T),AC compressor relay(T)
    23 Y/G.......CHTS
    24 B.........Oxygen Sensor (shielded)
    25 L/G.......Throttle Valve Switch
    26 B.........CHTS, AFM
    27 B/W.......Pin #35
    28 B.........Pin #36
    29 PU........Combo Meter (Vehicle Speed Sensor)(T)
    30 Y/G.......AFM
    31 B.........AFM (shielded)
    32 -no pin-
    33 -no pin-
    34 G/W.......Ign Coil, 15A Fuse in Fuse Block
    35 B/W.......Pressure Reg. Control valve, EAI solenoid, EFI Relay, EGR control ...solenoid, CAS (shielded), Idle-up solenoid (NA), AAC valve (T), AFM
    36 B.........Bonding Wire for Shielding, CAS (shielded), CAS, body ground
    102 G/B.....Injector #2(T) Injector #3 (NA)
    103 G/L.....Injector #3(T), Injector #5 (NA)
    104 G/Y.....Injector #4(T), Injector #2 (NA)
    105 G/R.....Injector #5(T), Injector #4 (NA)
    106 G/W.....Injector #6
    107 B.......FICD Solenoid Valve(T & NA), Pins #109, 112, 113, body ground
    108 B.......Fuel Pump Relay (shielded), Fuel Pump (shielded)
    110 -no pin-
    111 -no pin-
    114 R.......Fusible Link, Injectors 12+ source
    115 -no pin-
    Notes:
    1 most control voltages seem to be negative such as fuel pump, injectors and the Ignition coil. Because of this, a good ground is important!
    2 The injector wiring difference between T’s and NA’s might be a contributing cause to hesitation’s after the injector campaign. There is not much of a difference between the T and NA’s wiring, most notably the difference in wiring of the FICD and AAC valve on the T’s and FICD and Idle-up solenoid on the NA’s.
    3 not many differences between the 84 and 86, notably the lack of the fuel pressure regulator control module (pin #115). Also noted are the lack of the headlight switch (pin #22) which probably effects the idle speed and the addition of the AIV (air injection valve) on the 86 models.
    Paul
    I am here to help...
    The actual ECU pinouts are the same as far as I remember... that is, you can put any Z31 ECU into any car. The differences are in the engine wiring harness. You have to swap a few pins around on the harness where it connects in the car (for things like fuel pump, etc).
      I suppose this means that as long as I know the pinout of the ecu...that now I go to the EFI to Body harness with a multimeter and check to make sure that it is leading to the appropiate sensor or location.
      Fun Stuff.
      Seems I'll be taking notes for the '87T. In regards to what changes had to be made to properly support a '88n/a ecu.
      I'll be doing the same later this year for the '88t...taking notes as to what changes had to be made to support an '88n/a ecu.
      *(I know the obvious O2 sensor differences)...it's just the actual wiring colors/locations similiarities/differences that are of the unknown.
        I pulled out the FSM when putting an 88 harness in an 85 car.
        I needed to swap 3 or 4 wires around on the engine-body harness plug as I recall. I know one was the coil/power transistor and maybe fuel pump? I should have written it down... but all the information is right there in the FSMs, just compare the two diagrams.
          yeah, I have an 86 fsm on cd...I have the white paper back version of the fsm for the 1988 models...and now, I just ordered the 1987 model year paperback fsm
          *I know I can view these online, it just sucks balls to do it that way....I like having complex diagrams on paper in front of me.
          **If this comes up in anyone elses romulator/NisTune adventures...take notes on what you found with your scenario and post it here in this thread. Maybe we can gather enough information to add to the current romulator sticky...and make it even more informative than it already is.
          Dan
            I think the thing is that most people don't swap the engine wiring harness when they do a engine/ecu/injector swap, so it's not commonly known that there is a difference in the body harness side.
              Alrighty...lacking information covered...update the Romulator page(permission from information source approved)
              http://tboz.no-ip.com/300ZX/Z31EFIHarne ... wiring.htm
              8)
              Dan
                I'll ask him if I can add it.
