Fuel Injector question
JaygotboostSenior Member- 137
I pulled some top feed injectors from a 93 Mercedes 500 SEL / Bosch part # 0-280-155-217 , they look like the 450 sel's everyone else gets but wondered If any one has used these ? The car had low miles and I paid dirt cheap for them . Thanks , I did use the search button but only found the 450's and 480's , I searched online but didn't get very much info , the car does come with 320hp .If you think everything is under control, your not going fast enough - Mario Andretti
Good , low cost hids , pm me for info …
http://s496.photobucket.com/albums/rr32 … ds%202008/ -
I was basically looking for any feedback on these , I'll have them tested to see how they flow and If good I'll look towards a tune with all the other stuff I have upgraded . I was surprised to see a wrecked 93 Benz 500 with 60k .If you think everything is under control, your not going fast enough - Mario Andretti
322hp from a 5.0L V8. Remember, it doesnt take as big of injectors to get 320hp from a 5.0L V8 as it does to get 320hp from a 3.0L V6. That car could get away with 260cc injectors and still make 322hp. If that were the case, they'll be no better than stock turbo injectors.Jaygotboost wrote: I searched online but didn't get very much info , the car does come with 320hp .[/b]- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Unless you can find the part number cross-referenced somewhere online, your best bet is to compare flow results to a stock injector to estimate their flow rate. -
WindzerSenior Member- 335
Check http://users.erols.com/srweiss/tableifc.htm
According to that they put out 197.6cc/min, but at an unknown PSI. -
If someone has alldata or similar service info access now all you need to do is look up the fuel pressure spec for that benz.Windzer wrote: Check http://users.erols.com/srweiss/tableifc.htm
