Check pressure at the fpr. I had one go out, and the car would not start with no fuel to injectors.
88 and 87 ecu's
Chuck Stong
http://www.300-plus.com
You said the shop didn't mark the placement of the distributor? Have you tried rotating or setting it near where it should be? Also, what kind of compression do the cylinders have?Originally posted by Andrew84zx
How can i check the compression if the engine is not started ???
Like 1 month before i took the engine out i think they where like 120 all across to board or some thing like that i can exactly remeber...
and if this ecu doesnt fix the problem ill put on another fpr also...
But all these parts worked before the engine was dropped out of both the cars...
OMG.... :roll: you`re killing me with all this.
check timing, check correct dist position, put down the beer and go back to square one. you can check spark and injector pulse by pulling the dist and spinning it with the key on. you will hear the injectors click and the coil click. pull a plug and/or injector to make sure something is happening. (spark/fuel), clamp down the injectors, check the fusable links. realise that there isn`t 2 o2 sensors on an 88 turbo, expecially on the lower intake.
i recommend you go to a book store and get a book on how fuel injected cars work because it really seems like you don`t have a grasp of the basics.
I dont have a 88 turbo 300zx ... I have a 1988 n/a VG30 maxima engine...
Any ways ive done all that stuff.
im cool now
sorry guye i found the issue all it was was the injector ground.....
weeks of trying to find out what is the problem finally i got it... I had it ground on the timming cover.....
Now since i can start it i have to fix this issue it has with not staying started unless you have the throttle chamber open..
