Stuck with a predrilled oilfeed-less VG33?
1/8" NPT to -4AN adaptor, -4AN turbo oil feed line, and a -4AN turbo oil inlet flange.
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
solostSenior Member- 268
I did something similar but had a friend weld a 1/8" bspt to a -4an that came with the SS line kit. I also recently had another left over -4an from the kit welded to the oil feed fitting that came on the holset, so thats another way to cheap out on fittings haha.vg33et -
Being that oil filter housing is aluminum its simple to retap to 1/8" NPT instead of 1/8" BSPT, so I just did that and it works out using the 1/8" NPT to -4AN fitting.solost wrote: I did something similar but had a friend weld a 1/8" bspt to a -4an that came with the SS line kit. I also recently had another left over -4an from the kit welded to the oil feed fitting that came on the holset, so thats another way to cheap out on fittings haha.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Chris86NA2T or 88sinZ posted this, and Grr did this on his engine as far as I was told.
Good picture. -
You and I discussed this, but you never told me anyone else thought of it/did it too :PCareless wrote: Chris86NA2T or 88sinZ posted this, and Grr did this on his engine as far as I was told.
Good picture.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
Or…
1/8 NPT female to 1/8 BSPT male Adapter
Couple that with your ol eBay T3 oil line. No drilling or tapping required.Cha iro
at least you gave it a whirl.
