I am going to be installing my built engine over the weekend and I will be using morgan style cam gears. I was going to lean towards getting more torque but am afraid I might exceed the dxd stage 4 clutches torque capacity. Any suggestions on where to place them? Car will be running nistune, 480cc injectors, walbro fuel pump, t3/t4 said to be good to around 550-600hp, forged pistons, brc 8.5:1 pistons, balanced, external wastegate, 3" turbo back no cat, again dxd stage 4 with fidenza flywheel, afco radiator, electric fan, large NPR intercooler, isky cams, ferrera valves, schnieder springs, new OEM lifters. I am planning revving to around 6700rpm maybe more if the car seems like it can take it. Specs for the cams are as follows from the sheet isky sent me with them.
Grind - 280-MEGA HYD
270-MEGA HYD
Lobe Center 119 deg
valve lift is calculated with rocker ratio of 1.5
INTAKE TIMING
DURATION 280 DEG
OPEN 21 BEFORE TDC
CLOSE 79 AFTER DBC
CAM LIFT .323
VALVE LIFT .485
VALVE LASH .000
EXHAUST TIMING
DURATION 270 DEG
OPEN 21 BEFORE TDC
CLOSE 74 AFTER DBC
CAM LIFT .310
VALVE LIFT .465
VALVE LASH .000
OVERLAP 37 DEG
THE ABOVE TIMING IS CHECKED AT (OPEN) LIFTER RISE
THE FOLLOWING TIMING IS TAKEN AT .050 LIFTER RISE AND GIVES A MORE ACCURATE DETERMINATION OF CAMSHAFT POSITION.
INTAKE
DURATION 232 DEG
OPEN -3 BEFORE TDC
CLOSE 55 AFTER BDC
EXHAUST
DURATION 221 DEG
OPEN 49.5 BEFORE BDC
CLOSE -8.5 AFTER TDC
270-MEGA HYD
Lobe Center 119 deg
INTAKE TIMING
DURATION 280 DEG
OPEN 21 BEFORE TDC
CLOSE 79 AFTER DBC
CAM LIFT .323
VALVE LIFT .485
VALVE LASH .000
EXHAUST TIMING
DURATION 270 DEG
OPEN 21 BEFORE TDC
CLOSE 74 AFTER DBC
CAM LIFT .310
VALVE LIFT .465
VALVE LASH .000
OVERLAP 37 DEG
INTAKE
DURATION 232 DEG
OPEN -3 BEFORE TDC
CLOSE 55 AFTER BDC
EXHAUST
DURATION 221 DEG
