turbocharger oil drain.
  • darkside
    darkside
    Member
    • 55
    is this the correct oil drain for our t3? if so it should also work for holsets? either way it's pretty cool.
    http://www.summitracing.com/parts/RUS-697070/
    and this looks like a handy oil pan turbo drain fitting:
    http://www.summitracing.com/parts/RUS-697090/
    Russell is on the ball
    BDG.
  • Careless
    Careless
    • 13279
    you could just use two of the first ones since it has an o-ring fitting and just use an o-ring fitting to back the flange when you fasten it to an N/A drain pan.
