Header Studs
  • 628sx
    628sx
    • 232
    #91
    So no further help eh? I've dulled 3 bits (at least twice over), shattered one, busted my de-burring tool, snapped an easy out, and mangled all my center punches… it's about to cost as much in tools as taking the heads off would cost me
    Turbo Rotories… 60% of the time.... they work every time..
  • Careless
    Careless
    • 13279
    #92
    did you pull the motor? you could raise the motor using a cherry picker by taking the hood off and pulling the motor up and you might have gained adequate clearance to do the job better.
    i was in your shoes when I first got my car and I ended up taking the motor apart because of it and then a fuckton of other things happened because of that.
    looking back, if I would have raised the motor I'd probably be way ahead of where I am with my car now.
  • Rustspecs13
    Rustspecs13
    • 283
    #93
    Sorry the welding trick has always worked for me. And I think I'm pulling my motor this weekend to fix my broken studs and do other things.
    seeds shipped from USA.
    splatter fake blood on fubar'd quarter and roll out.
  • 628sx
    628sx
    • 232
    #94
    hrmmm… those suggestions need to be tried!!
  • Returned Z31 Lover
    Returned Z31 Lover
    • 144
    #95
    Any year ls1 studs will work? Just tell the guy at the counter ls1 studs?
    THE ONE AND ONLY AE 2JZ Z31 IN THE WORLD
