High lift, solid flat tappet, roller rocker conversion kit
 WTMPMember WTMPMember- 31
 RocklinMike300zxSenior Member RocklinMike300zxSenior Member- 276
 What other modifications have been done to the engine? I feel like I am overlooking something obvious here but you're talking about a 100whp over stock NA so that's why I'm a bit lost. Would love to see that dyno profile if you can manage to decrease the file size. Could even get the graph and save it as a JPG or GIF.
 Stock crank, eagle rods, 85e heads ported by me with 1mm ferrea valves (flow 207 at max lift on the intake side), light porting on LIM, 96 mercury villager plenum (plastic or composite, not sure of material) with mod to plenum and larger throttle body, 10.8 to 1 comp, 42lb injectors, 1.5" headers, dry sump three stage. I can email the dyno sheet to you if you think you can post it up. Aaron Kelley aaron.kelley3@gmail.com
 What are you using for engine management?- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 NissanXRMASenior Member NissanXRMASenior Member- 3245
 Essentially turning the plenum, throttle body. and 3ft. of 4"intake tube into plenum for delay of the choke point from the restrictor. Long story short it takes longer to evacuate all of that plenum.
 I want to see dyno without restrictor!- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 I want to see the dyno without the restrictor as well. Also want to chase the cam development a little more. Pipemax estimating that there is still 24cfm that didn't get turned into hp. Might need more header, cam and compression to make it happen. That may be enough to get close to 300 whp N/A. There is also more flow to be had with a port that is maxed out.
