turbo gaskets
  • Lykoi
    Lykoi
    • 241
    turbo gaskets
    I'm looking at a stainless crush gasket from treadstone.
    Is the crush gasket a better setup or should i be looking for regular gasket material?
    88T.... needs assembly
  • SATAN
    SATAN
    • 6782
    What are you sealing? I'm pretty sure If you are sealing cast iron to cast iron, no gasket is needed. If you are sealing steel to cast iron, then any turbo gasket should work. I prefer the steel crush gaskets.
  • Lykoi
    Lykoi
    • 241
    I had no effing clue you could do cast iron to cast iron with no gasket.
  • shromy
    shromy
    • 2189
    I would use one, the factory used one so why would you not?
    Hmmm, Whats next?
    84ZXT
  • Careless
    Careless
    • 13279
    #5
    if you seal cast iron to cast iron with no gasket, you have to have both the turbo and the manifold milled flat.
    but i use a stainless crush gasket anyways.
    i think i ordered this one
    http://www.frsport.com/FRS-Stainless-St … _9940.html
    it's a divided gasket too.
  • SATAN
    SATAN
    • 6782
    #6
    shromy wrote: I would use one, the factory used one so why would you not?
    I agree with this. The cast iron to cast iron is just something I read a while ago. Never tried to apply it though.
  • Careless
    Careless
    • 13279
    #7
    It definitely works. Ritter said that's what he did the last time, so I told my friend to have his scooby turbo and turbine housing milled because he couldn't get a gasket in time for the weekend. It hasn't leaked for a year now.
  • shromy
    shromy
    • 2189
    #8
    [quote]Careless wrote: [quote=SATAN]
    A milled surface is different than a 20yo one and a new one. Yes it does work, just look at the stock elbow to exh housing section. No gasket there. But the gasket is what 5 bux maybe, alot cheaper than milling unless you have a buddy.
    Hmmm, Whats next?
    84ZXT
  • Lykoi
    Lykoi
    • 241
    #9
    Thanks for the input, been leaning towards crush anyway. Though I'm going to have to keep that cast iron thing in mind in case I ever need it.
