-8 or -10 oil lines?
fastclownJunior Member- 5
I'm adding an oil cooler and seperate filter on the VG30. Should I use -8 or -10 lines? What are the pros and cons? The cooler is set up for a -10 but I can buy a reducer… Thanks. -
SATANSenior Member- 6782
I would think the pro's and con's would be self explainitory. If you run a -8 then your pressure will stay higher than it would with a -10. On the other hand if you run a -10 it will flow more oil doing one of two things. It could cool more oil or it could soak the cooler faster with heat, but you said it was set up for -10. So I dont see heat soak being a problem. I would run -8 as that is 1/2" and I would think that would be plenty big and not drop oil pressure too much, I guess.85 Z31 6.0 LSX turbo 766whp/792wtq
I used -8 on my cooler without any problems.86 hardtop shell, 93 SC300 engine, 95 soarer bellhousing, 91 supra transmission, 95 Q45 differential hubs and driver's side axle, 1992 300ZX turbo driver side axle and calipers, 2004 350Z Rotors, 87 300ZX front end/hood, 1999 Viper radiator, 1992 Mustang throttle body. Lots of glue and tape to keep it all together.
