can anyone find me flow specs on this turbo?
CurbsquirrelMember- 58
AiResearch T04B32
comp: a/r .60
ex: a/r .84
I have this turbo, from what i've found, its used on John Deer diesel tractors..$700-$1000 turbo…
seems like a relatively small T04, the compressor housing is still significantly larger than the stock T3, but the comp wheel looks to be pretty close in size, and doesn't the stock T3 have a comp. a/r of .60?
Any info would be great, tryin to figure out if this would be a good turbo to use for my 450 hp goals, either rebuild and use it, or make a t3/t4 from it!
Thanks for any info !!!
here is pretty much what it looks like…
'71 240z
z31 swapped -
shromySenior Member- 2189
Laggy as shit! Come on say something different.Hmmm, Whats next?
84ZXT -
saw this in NYZdude's post about the crap cm intercooler piping setup post…his turbo he lays down by the stock t3 looks alot like the t04..identical compressor housing with what i have from what i can tell..not sure if his is the full t04 or a hybrid??
maybe he'll chime in and lemme know from experience runnin it?'71 240z
z31 swapped -
Looks like a T3/T4 hybrid built out of a stock T3 based on what I can see of the turbine housing and exhaust elbow.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
