Refresh
This website z31performance.com/forum/z31-performance-upgrade-forums/engine-mechanical-aa/2075-compression-test-on-cold-motor is currently offline. Cloudflare's Always Online™ shows a snapshot of this web page from the Internet Archive's Wayback Machine. To check for the live version, click Refresh.
Compression test on cold motor?
  • Compression test on cold motor?
    Does anyone know what kind of numbers one should see if they do a compression check on a cold motor that is sitting on an engine stand. My friend wants to know. He will be doing the compression check by turning to motor over with a wrench. Anyone have any ideas? Thanks in advance.
    440whp on pump fuel and the STOCK MAF
    You can not do a proper compression test while cranking the engine over with a wrench!!!
    Although, you could perform a cylinder leak down test!
      umm i don't think you will be able to turn it by hand fast enough to get an acurate reading....
      but the haynes manual states this.....
      standard =
      non-turbo 173 psi @300 rpm
      turbo 165 psi @300 rpm (169 psi on 1988 and later models)
      minimum =
      non-turbo 128 psi @ 300 rpm
      turbo 121 psi @ 300rpm (125 psi on 1988 and later models)
        maybe he has the tranny and the starter rigged up somhow in the engine stand with a 12v battery ready to turn it over hmmmm, hmmmm, ever think of that hmmmmm! :P
          That's one hell of an engine stand!!!
