Remote Oil Filter Adapter
BLOZ UPSenior Member- 2971
When swapping in my VG33 in my S30, I won't have room for any of the 3.3L oil filter adapters. So I'm going to run a remote oil filter. I need the adapter plate that goes to the oil filter (also, what size do I get? I want something large but common). I just need the filter adapter, not the block one. All the standalone ones I see are for the block.
I see cheap, ugly Hayden complete kits for $50, but it's going to look whack with my push-lok AN lines. And on the other end I don't really want to pay $200 for a nice kit when I'm only using 1/3 of it. So, who sells nice billet oil filter adapters?BLOZ UP.com
I see one affordable kit on eBay. This is acceptable, I suppose.
http://www.ebay.com/itm/BLUE-ALUMINU…1df9c8&vxp=mtr
Anything else out there?BLOZ UP.com
85NA2TSenior Member- 1111
I had one of those^ They work fine just DO NOT run your oil feed line for the turbo from there. Those ports on the side do not go through the filter first."If your car cant do a burnout from a 60mph rolling start, then your engine needs more work."
Shooting for 500whp
Hrm.... I do need a place for my oil feed.BLOZ UP.com
Eh? Its out of one of the block oil passages, post filter.Originally posted by G-EThe factory oil feed hole for the turbo can't be filtered either being that far away ?- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
floridaZSenior Member- 2781
Not sure what you'd use the extra holes for. Oil cooler… if you didn't run it in-line with the filter maybe.Feedback- viewtopic.php?f=18&t=19840
GregmaticSenior Member- 2193
I wouldn't have a problem running an oil feed off a pre-filter port. The oil in the car is essentially a closed system, it is being filtered anyway and that oil is constantly being recirculated. Of course there could be some particulate that arises between point A and point B but whatever.
I would highly recommend against this. Imagine a bearing goes. Goodbye turbo.Originally posted by GregmaticI wouldn't have a problem running an oil feed off a pre-filter port. The oil in the car is essentially a closed system, it is being filtered anyway and that oil is constantly being recirculated. Of course there could be some particulate that arises between point A and point B but whatever.Usual Z31 suspect: Garage Queen (aka broken)
I picked up a Circuit Sports one. AFAICT, it's the same as the chinese knock-offs. Or rather, the knock-offs are the same as it. Comes with some -10 AN lines though. So, I'm tapping the side of the 3.3L oil pump for these lines. Is NPT the way to go? I'm going to have to bore it out a bit to fit a 3/8" NPT to -10AN fitting. If there's another option to get to -10 AN, let me know now before I get ahold of a drill.BLOZ UP.com
What's the current fitting bore on the 3.3 oil pumps? 1/8? I would just do what you are doing. 3/8 npt to 10 an is pretty common.Originally posted by BLOZ UPI picked up a Circuit Sports one. AFAICT, it's the same as the chinese knock-offs. Or rather, the knock-offs are the same as it. Comes with some -10 AN lines though. So, I'm tapping the side of the 3.3L oil pump for these lines. Is NPT the way to go? I'm going to have to bore it out a bit to fit a 3/8" NPT to -10AN fitting. If there's another option to get to -10 AN, let me know now before I get ahold of a drill.Usual Z31 suspect: Garage Queen (aka broken)
12mm hole right now. Looks like it can be drilled out the radius 1.5mm with plenty to spare. I think. My 1/4" tap fits fine, but 1/4" NPT fittings narrow it down quite a bit to nearly half the diameter. Similarly, I can only find a -8 AN adapter for 1/4" NPT.BLOZ UP.com
Looks like I'll be getting a new oil pump since the current one has stripped screws now. The adapter came in, looks real nice. Some of the ports could be smoothed out and there are metal shavings that need to be removed though.BLOZ UP.com
I got a modified, factory oil filter ped. with the lines ran into something like that kit you just bought. If you would like to see pictures LMK.89' Turbo-R.I.P. (scrapped)
Completely forgot about weld on AN bungs. I'm going to see what my local race shop has or order online. I'd much rather do that than have to drill and use a NPT->AN adapter.Originally posted by BLOZ UP12mm hole right now. Looks like it can be drilled out the radius 1.5mm with plenty to spare. I think. My 1/4" tap fits fine, but 1/4" NPT fittings narrow it down quite a bit to nearly half the diameter. Similarly, I can only find a -8 AN adapter for 1/4" NPT.BLOZ UP.com
