link133 link134 link135 link136 link137 link138 link139 link140 link141 link142 link143 link144 link145 link146 link147 link148 link149 link150 link151 link152 link153 link154 link155 link156 link157 link158 link159 link160 link161 link162 link163 link164 link165 link166 link167 link168 link169 link170 link171 link172 link173 link174 link175 link176 link177 link178 link179 link180 link181 link182 link183 link184 link185 link186 link187 link188 link189 link190 link191 link192 link193 link194 link195 link196 link197 link198 link199 link200 link201 link202 link203 link204 link205 link206 link207 link208 link209 link210 link211 link212 link213 link214 link215 link216 link217 link218 link219 link220 link221 link222 link223 link224 link225 link226 link227 link228 link229 link230 link231 link232 link233 link234 link235 link236 link237 link238 link239 link240 link241 link242 link243 link244 link245 link246 link247 link248 link249 link250 link251 link252 link253 link254 link255 link256 link257 link258 link259 link260 link261 link262 link263 link264 link265
Rocker arm
  • joselito76
    joselito76
    Junior Member
    • 27
    Rocker arm
    I had been looking ,but I haven't found anything yet ,so I am going to ask.By the way this is my first post .I am new on the 300 community.I had own few 350z and now a G37 all modified. I wonder if they are rocker arm with roller bearings for this engine?
  • G-E
    G-E
    Junior Member
    • 6320
    Sort of… there is no roller lifter which is where most friction is, and they still use a bronze bushing on the rocker shaft, so I doubt it's worth the expense, close to $1500
    Tell us your goals with the car and we can tell you how to reach it, the vg is an oddball in the market, the same stuff you think works doesn't, and things that should be available aren't
  • joselito76
    joselito76
    Junior Member
    • 27
    Well i am looking to my options .Good power ,very good power and daily drive.The car is in the garage and I dont want to do anything until I am completely sure of what I want.Stay with this engine "my main plan" or swap it with something more easy to modified.
  • G-E
    G-E
    Junior Member
    • 6320
    Would 400hp boosted work for you? Keeping in mind you'll have a 600lb savings over the g37 if not more…
    Staying non-turbo will be very difficult to get past 250hp, the engine just isn't designed that way.
    Sooo simple formula: a good condition vg33 from a junkyard quest/villager, swap all the factory z31 turbo stuff on it, maybe port the heads, throw in some reground cams, upgrade the turbo; then for engine management the most economical is getting nistune installed in your ecu, reprogrammed for larger injectors, and properly dyno tuned…
    So a simplistic price list:
    - nistune $400ish
    - turbo $250-800
    - injectors $200-500
    - vg33 $100-250
    - turbo swap parts if you don't already have $200-400
    - reground cams $200ish
    - full 3" exhaust $400-800
    - tuning $???
    Of course I'm a driving guy, more than a speed nut, so for me it's all about the suspension, that's what makes a car really fun for me
  • joselito76
    joselito76
    Junior Member
    • 27
    #5
    Thanks G-E .All that sound great.So you recomend goiing with the 3.3 ? 400 with stock internal? And suspension is together with power.Like I heard some where you can only go as fast as you can breake or handle or something like that.But trully I would like 500 to the wheels if is posible.Again thanks for responding.
  • jaqattack02
    jaqattack02
    • 1185
    #6
    Me thinks you have a lot of reading to do before you keep going with the questions.
    I would advise starting here, read all of it: http://www.redz31.net/
    My 1986 Turbo Build
  • joselito76
    joselito76
    Junior Member
    • 27
    #7
    I am pretty sure I do. A lot to learn . I just started, and thanks for the replies.
  • joselito76
    joselito76
    Junior Member
    • 27
    #8
    I tell you what. After15 minutes of readings I have a smile from ear to ear .First there is a lot of potential on this engine .Second I had never seeing a write up like this not on the VQ community or even on the Subaru community .I am going to be so happy with this car.
  • floridaZ
    floridaZ
    • 2781
    #9
    Before you get it on the road, an S-chassis rear suspension swap would be a good idea. IMO, the semi-trailing rear suspension, and it's lack of adjustment, is the biggest weak point of the whole car. It's not hard or really even that expensive to make power with these cars, just as long as you can read and don't mind a little fab work.
    Feedback- viewtopic.php?f=18&t=19840
  • joselito76
    joselito76
    Junior Member
    • 27
    #10
    Floridaz. I don't mind at all, that make the car more interesting. As I can tell. I do have a lot to learn. Just like I did with my other cars. And again Thanks for the feedback guys.
  • G-E
    G-E
    Junior Member
    • 6320
    #11
    When you get serious, and set aside a serious budget, I have a BBK, rollcenter adjusters, subframe swap kit and many more lovely race tested things for the driving side of things
  • joselito76
    joselito76
    Junior Member
    • 27
    #12
    Noted
  • Axel kain
    Axel kain
    Moderator
    • 1221
    #13
    "Race tested"
    sigpic
