Who's running 17+psi
 NuCOTechMember NuCOTechMember- 76
 Who's running 17+psiI'm looking to run somewhere in the 17-25psi range. Are the 6E's plugs going to be fine or will I need to step up to 7's.
 Also, anyone running 550cc injectors with nistune? Curious as to what K factor is working for you.
 ButterSenior Member ButterSenior Member- 1519
 You need 7's after 15psi IMO.
 Make sure if you have a gutted plenum, that the top is welded good with nice thick metal. I thought it only happened on Fast and the Furious, but I blew the welds on my intake at 21psi.sigpic
 matt85turboSenior Member matt85turboSenior Member- 101
 NGK 1095'S are one stage colder. I would recommend those as well as lowering the plug gap to around .030 or so. I run mine at .027 and do not have issues with blow out.
 7's at .03-.033 gap. Don't kill your gas millage unless you are having issues with blow out.Usual Z31 suspect: Garage Queen (aka broken)
 Big Slappy ZSenior Member Big Slappy ZSenior Member- 237
 I just lol'd really hardOriginally posted by ButterYou need 7's after 15psi IMO.
 707Redz31Senior Member 707Redz31Senior Member- 375
 I have 550s. 553cc to be exact high impedance but I have a mustang gt airflow sensor (the "other" ford maf curve in nistune good for 500whp) So that needed k adjustments back up. With both my k is 200.Originally posted by NuCOTechI'm looking to run somewhere in the 17-25psi range. Are the 6E's plugs going to be fine or will I need to step up to 7's.
 Great, thanks for that info. I will use 200 for a starting point and I should be able to go from there.Originally posted by 707Redz31I have 550s. 553cc to be exact high impedance but I have a mustang gt airflow sensor (the "other" ford maf curve in nistune good for 500whp) So that needed k adjustments back up. With both my k is 200.
 harwood909Senior Member harwood909Senior Member- 131
 There is a tick box you can check when adjusting injector size that will recalculate K-value on it's own. I would go by that as injectors swing the K-value one way and the MAF has the opposite affect on it. I don't remember which one is which. It is in one of the Nistune Manuals.1985 300zx N/A - June 4 2012 Sold to Austin Irwin
 1987 2+0 N/A - March 19 2014
 1987 2+0 Turbo - May 6 2014
