intercooler piping, pathy intake, hx35
 drb5721Senior Member drb5721Senior Member- 289
 intercooler piping, pathy intake, hx35Alright guys. Need some insight. I'm running an hx35 relocated. Also plan to use the pathy plenum. Intercooler is one side outlet backdoor inlet. Inlet is coming straight off of compressor housing to backdoor inlet. Plan to run outlet to throttle body by looping it back through the wheel well through a hole. Issue I have is. Throttle body clears turning housing but I need a way to get a good bend to cut back across the front of the engine. Any ideas?
