VG33 Crank Spacer for Z32 Pulleys
 BLOZ UPSenior Member BLOZ UPSenior Member- 2971
 I had my spacer machined to fit inside the Z32 ATI Damper. Works!
 Had some issues pushing the pulley on, but once I torqued it all the way on (difficult since a proper pulley installer doesn't fit) things worked out.
 So the ATI damper works with the VG33. Comes real effin close to the timing cover/timing cover lower bolt, but doesn't hit.
 Not that timing marks are indexed incorrectly.BLOZ UP.com
 ZEricMZSenior Member ZEricMZSenior Member- 455
 I will take one, message being sent.Build Log Link: http://z31performance.com/showthread…-VG33-HX35-WIP
 Sale pending for last one.BLOZ UP.com
 zdriver_kadoMember zdriver_kadoMember- 100
 One left!BLOZ UP.com
 amrebootBanned amrebootBanned- 9875
 Heya.... I need one of these.
 BLOZ UP, I know you don't have any left, but I am curious if anyone has one that they are not using.
 Lemme know…
