oem t3 oil feed inlet flange dimensions
I've been searching and can't find anything, so I'm trying to find out what the diameter of the factory oil feed flange is ( mid bolt hole to bolt hole ) pertaining to my water cooled t3 turbo. I'm wanting to buy a nice 4an oil inlet flange but need to make sure I'm getting the correct one. Thank you guys.http://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (: -
Any T3 oil feed flange/adapter will work perfectly, they're all based off the Garrett design.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
