link3325 link3326 link3327 link3328 link3329 link3330 link3331 link3332 link3333 link3334 link3335 link3336 link3337 link3338 link3339 link3340 link3341 link3342 link3343 link3344 link3345 link3346 link3347 link3348 link3349 link3350 link3351 link3352 link3353 link3354 link3355 link3356 link3357 link3358 link3359 link3360 link3361 link3362 link3363 link3364 link3365 link3366 link3367 link3368 link3369 link3370 link3371 link3372 link3373 link3374 link3375 link3376 link3377 link3378 link3379 link3380 link3381 link3382 link3383 link3384 link3385 link3386 link3387 link3388 link3389 link3390 link3391 link3392 link3393 link3394 link3395 link3396 link3397 link3398 link3399 link3400 link3401 link3402 link3403 link3404 link3405 link3406 link3407 link3408 link3409 link3410 link3411 link3412 link3413 link3414 link3415 link3416 link3417 link3418 link3419 link3420 link3421 link3422 link3423 link3424 link3425 link3426 link3427 link3428 link3429 link3430 link3431 link3432 link3433 link3434 link3435 link3436 link3437 link3438 link3439 link3440 link3441 link3442 link3443 link3444 link3445 link3446 link3447 link3448 link3449 link3450 link3451 link3452 link3453 link3454 link3455 link3456 link3457
6262 in stock turbo location?
  • Z31Turboed
    Z31Turboed
    Newbie
    • 136
    Is a PT 6262 too big to fit in the stock location?
    1985 Z31 Turbo sans AC
  • FrozenZ
    FrozenZ
    • 584
    rick88ss is running that. But if you are ditching A/C why not just relocate the turbo, it makes life waaaaaayyyy easier.
  • HarvesterUT
    HarvesterUT
    Member
    • 74
    It looks like rick88ss is also running a VG33. Is that turbo too big for a VG30?
    1988 300ZX Turbo Shiro Special
  • ozzyrulez
    ozzyrulez
    • 631
    As far as I know he's currently running a VG30 and had removed the VG33
    2007 Nissan 350Z Base: 13.476 @ 103.870 MPH
    1988 Nissan 300ZX Shiro Special New Setup 11.979@117.34 MPH
  • Rick88ss
    Rick88ss
    • 2433
    #5
    Currently running a vg30 with a 6262. It fits in the stock location even with the bigger S housing.
    Shiro #443
  • HarvesterUT
    HarvesterUT
    Member
    • 74
    #6
    Rick,
    If you could do it again, would you stick with the 6262 or go with something else (HX35, etc.)? You seem like you've done this a few times, and I am just getting started. Thanks.
  • FlawleZ
    FlawleZ
    • 1971
    #7
    The 6262 should never be compared to an HX35. That's such an insult…
    I'll post a pic of my 6262 in the stock location before my tubular manifolds later tonight.
    545 RWHP & 540 RWTQ
  • HarvesterUT
    HarvesterUT
    Member
    • 74
    #8
    What clutch setup you guys running?
  • FlawleZ
    FlawleZ
    • 1971
    #9
    I'm running the Stage V+ DXD South bend pressure plate with a kevlar solid disc.
    545 RWHP & 540 RWTQ
  • HarvesterUT
    HarvesterUT
    Member
    • 74
    #10
    Good to know. I've driven the DXD stage 3 daily, and I find it easier to drive than my old 350z.
  • 300zxturboftw
    300zxturboftw
    • 3709
    #11
    This guy…listen to this guy.
  • Rick88ss
    Rick88ss
    • 2433
    #12
    Originally posted by HarvesterUT View Post
    Rick,
    6262 is a very good size turbo thay's capable of making over 600whp on about 25-28 psi of boost.
    How much power are you looking for? Street or drag/top end performance?
    Shiro #443
  • HarvesterUT
    HarvesterUT
    Member
    • 74
    #13
    Rick,
    See my thread about that issue here. But to save you the click, basically, I want to keep my A/C and everything I can in stock locations. Power goal is ~500hp primarily for the street. Don't need a drag monster and certainly don't want to have to flog the engine just to have fun. Wide, mid-range power band is what I like. I intend to build the bottom-end & heads, plenum/exhaust flow, and fuel/ecu work, of course.
    Any advice you have is greatly appreciated. Thanks!
  • Rick88ss
    Rick88ss
    • 2433
    #14
    Check out this thread here
    http://z31performance.com/showthread…precision+5857
    I would go with a 6262 with a T3 exhaust .63 housing
    Shiro #443
  • Z31Turboed
    Z31Turboed
    Newbie
    • 136
    #15
    Is that because the T3 outlet will bolt right up?
