Differences between 21V and 85E head casting
HarvesterUTMember- 74
Both were used on the W-series 3.0L motors, but I've never found any info that describes the differences between the two head castings other than the 21V being the early W-series head and the 85E being used on later vg30's.1988 300ZX Turbo Shiro Special -
midianSenior Member- 421
find description of owo heads. info about 21v and e85 described fully there. -
707Redz31Senior Member- 375
88sinZSenior Member- 2019
There's no major differences that would set them apart.
If you're running a W-series engine it's beneficial to use the OWO heads given the opportunity. -
nismopuAdministrator- 2221
85e and OWO are the same port shapes the only difference on the OWO are the 10mm exhaust studs."Its the s12's sexy over weight step daughter, the z31"
