link1463 link1464 link1465 link1466 link1467 link1468 link1469 link1470 link1471 link1472 link1473 link1474 link1475 link1476 link1477 link1478 link1479 link1480 link1481 link1482 link1483 link1484 link1485 link1486 link1487 link1488 link1489 link1490 link1491 link1492 link1493 link1494 link1495 link1496 link1497 link1498 link1499 link1500 link1501 link1502 link1503 link1504 link1505 link1506 link1507 link1508 link1509 link1510 link1511 link1512 link1513 link1514 link1515 link1516 link1517 link1518 link1519 link1520 link1521 link1522 link1523 link1524 link1525 link1526 link1527 link1528 link1529 link1530 link1531 link1532 link1533 link1534 link1535 link1536 link1537 link1538 link1539 link1540 link1541 link1542 link1543 link1544 link1545 link1546 link1547 link1548 link1549 link1550 link1551 link1552 link1553 link1554 link1555 link1556 link1557 link1558 link1559 link1560 link1561 link1562 link1563 link1564 link1565 link1566 link1567 link1568 link1569 link1570 link1571 link1572 link1573 link1574 link1575 link1576 link1577 link1578 link1579 link1580 link1581 link1582 link1583 link1584 link1585 link1586 link1587 link1588 link1589 link1590 link1591 link1592 link1593 link1594 link1595
Ive been looking for some aftermarket cams for a w series Na
  • jcs512
    jcs512
    Banned
    • 22
    Yes you read it right. N.a. aftermarket performance cams. Ive done some mild searching and was wondering if someone can point me in the right direction. I'm sure ill get the normal Na2t responses . I don't care and am doing an all motor build for the hell of it.
  • turbofedz
    turbofedz
    • 289
    Look up Schneider cams.
  • V8srfun
    V8srfun
    • 192
    There is nothing wrong with a good ba build as long as your goals match your build
  • Axel kain
    Axel kain
    Moderator
    • 1221
    ISKY also offer good grinds. there was a group buy not too long ago, and they have specs listed in it, maybe near page 7, but sifting through it may be annoying.
    sigpic
  • Reds89
    Reds89
    • 318
    #5
    I agree with your intent to build an NA and the posts above. If I ever get the time and resources (i.e. $), I would love to build a kick ass NA motor that revs high and fast, that sounds as good as a V6 Nissan engine can. However, going turbo has its fun and sounds too…
  • Gregmatic
    Gregmatic
    • 2193
    #6
    Shcneider, ISKY are the most commonly used companies but you may also be able to find some Nismo cams. Any company that regrinds cams can do a custom set for you if you provide the specs but most of us use the aforementioned because their in-house grinds come in various levels of aggressiveness for both turbo and N/A.
  • Steviec
    Steviec
    Junior Member
    • 1
    #7
    I sent my stock cams out to Crower and had them regrind mine for $100.00 each. Added some duration and moved the power band up 500 or so Rpms.
