HKS 3mm Copper head gaskets reused?
ralph50Member- 53
How many times can the be reused?
I have some on my Z and have installed them twice.
They were not cheap and I would like to reuse them again. -
88sinZSenior Member- 2019
Ask yourself. Do you want to take apart the engine again due to a leaky head gasket? Replacing one is just peace of mind. If you do re-use it I would highly recommend letting a professional engine builder go thru the gasket to determine if it's reusable.Usual Z31 suspect: Garage Queen (aka broken)
My question is why are you removing and installing then 3x's?87T, My build thread http://z31performance.com/forum/z31-…lee-s-87t-rb26 -
ozzyrulezSenior Member- 631
Sometimes I feel like I'm the only one still using OEM headgaskets -
You're not. Unless you're going for lots of boost, the stock gaskets work fine.Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
I've had the OEM gasket up to 26psi with no issues. That was with OEM head bolts too. I like to live dangerously lol -
ralph50Member- 53
I have had said gasket for like 20 years.
It was super expensive back then.
I was just curious. From what I was told back then the gaskets were resuable.
This one has been used 2 times already.
