HP Goals on my NA2T build and Advice!
 kyle_89zJunior Member kyle_89zJunior Member- 8
 HP Goals on my NA2T build and Advice!Hey guys im fairly new to this forum and this is the first time im posting. Ive started my NA2T on my 89 2 seater 5 speed and ive been over all the build threads and dyno sheets to try and estimate my power when im done. I will be doing the following:
 VG33E swap (Vg30 crank and accessories)
 Stock turbo injectors
 T3 in stock location
 JWT S2 cams and spring set
 Stock ECU mapping
 MPC to 10 psi
 3" turbo back CM exhaust
 Z32 TT fuel pump (mine took a shit and had it laying around so why not)
 Gutted plenum
 50/50 water/meth injection (chose this over intercooler setup just for the fact I want AC and don't have access or skill to make my own piping)
 Ive done my research but any advice would be greatly appreciated seeing as this is my first NA2T build. Im estimating it to be 250 - 300hp based off other builds ive seen on here but I could be wrong. Thanks in advance.
 Axel kainModerator Axel kainModerator- 1221
 not too bad off. if youre interested in an intercooler setup that can accommodate A/C, I'll likely have one for sale soon, as long as youre comfortable cutting a hole in the fender well.Damn dirty angels....these cars!
 sigpic
