Upgraded springs absolutely necessary for Isky 270 cam?
GregmaticSenior Member- 2193
I know I should upgrade to the 110 lb Schneider springs but just wondering if that is absolutely necessary on a motor that will likely never see north of 5500 rpm. Am I correct in presuming that there will no be no issues at idle or mid-range rpm?
amrebootBanned- 9875
I ran the Schneider 270 cams with VG33 outers and VG30 inners. About a 15% increase in spring strength.
I had no problem taking it up to 6700-7000 rpm.
So, you will be fine. But to argue, its only $100 to upgrade.
One of those "might as well". Ya know? -
Thanks.....Yeah, I know.......just feeling pretty unmotivated these days to do any work at all, especially when it isn't absolutely necessary
CrazySenior Member- 619
I have ben running stock valve springs with Schneider regrinds for years.Black 1986 300zx Turbo coupe (Chuki)
Axel kainModerator- 1221
yeah, Im on stock springs with Isky ~270'sDamn dirty angels....these cars!
sigpic -
