What SATAN has been up to
SteveZSenior Member
- 535
2+2turboSenior Member
- 556
MrwassmanNA2TSenior Member
- 2319
FlawleZSenior Member
- 1971
Good....night....
What are the specs on the turbo? Engine?Originally posted by Andrew84zx
SteveZSenior Member
- 535
FlawleZ wrote: Good....night....
What are the specs on the turbo? Engine?2005 whore magnet -
Jason84NA2TSenior Member
- 2909
I knew hw was up to something.... but this completely blindsided me. That is HOT. Hope he hops in to give us some info!
https://fund-solvaren.com. -
t70Senior Member
- 104
your turbo is bigger than my turbo! hehe… yikes! I love that front mount throttle body! that must flow like hell!8.5 custom arias pistons (.020 over)
eagle rods
t70 turbo (man was that a squeeze)
38 mm external wastegate
mild port/polish
3 angle valve job
custom intercooler piping
twin external intakes with z32 maf
rad moved back
3" exhaust with only a resonator
romulator
420cc injectors
custom body work, homemade oil lines and fittings..
walbro 255lph in-line fuel pump.... and lots of headaches… lol -
SATANSenior Member
- 6782
Q45 throttle body
860cc siemens injectors
Eagle rods
J.E. pistons (rings gapped to .020 on top and .024 on bottom) that way the top ring stays seated during combustion.
Block o-ringed
sheet metal intake
all -8 an fittings and lines
custom fuel rails
dual walbro 255lph's
Electromotive TEC2
4in turbo back exhaust
cams, ported and polished heads and a lot of other junk. you know the basic stuff to hold and make lots of power.85 Z31 6.0 LSX turbo 766whp/792wtq
04 GTO, LS6, big cam, porting, N20… underway for summertime daily driver. -
88TJunior Member
- 22
Wow that turbo is unreal! Fire it up and get some clips online, Im sure everyone here would love to here that monster! -
- 2909
Now THAT is a setup.
Finally.
Why has it taken this long for people to truly build a VG to it's potiential? Kudos. You and Steve are going to probably have the fastest Z31's in the nation. Heck, I'll be happy if I'm still in the top 10 in a couple years.
Are you running the twin walbros in parallel both feeding a -8AN hardline from the tank? I was thinking of doing that same thing in preparation for my little 'project' here. -
SATANSenior Member
- 6782
two walbro's running parallel on -6 stainless braided into a -6 -6 -8 Y then into hardline to the engine bay up to the filter with is also -8 in and out then -8 stainless from the filter all the way to through the rails to the regulator and -6 hard line back to the tank.85 Z31 6.0 LSX turbo 766whp/792wtq
SATANSenior Member
- 6782
The car WILL be bad ass. however once I get it back together its not going to be insainly fast yet. maybe low 10's with busting axles a lot. Axles and a clutch. But I have to put the car on hold for a while due to the fact that I'm getting married in june of next year. gotta start seriously saving for that. I figure if she lets me spend as much time and money as I want on the z( that and she loves cars) then I can do the wedding thing.Attached Files- 00f0f_gCAu4XCUTPZ_600x450.jpg (35.2 KB)
- 2319
OR-ZmanSenior Member
- 811
Now that is a going to be a nice set up man. Major kudos to you....
Congrats on the marriage…I have one coming up also. :shock: Dont let the flowers, caterers and other BS drag you into the poor house. It can be tough, but a wedding doesnt have to break the bank, or interfere with the Z. :wink:
Show them my motto…Just stand back and throw money.
Reliable performance costs more. -
SATANSenior Member
- 6782
WaZZ300 wrote: holy tits…4inch exhaust.
http://racingsouthwest.com/forums/index … 12&CID=80885 Z31 6.0 LSX turbo 766whp/792wtq
