cam grind suggestions
mojoSenior Member- 209
hey im sending out my stock vg30e cams to schnider racing soon and i was just looking for some sugestions on what grind to get to have good mid range and idle i emailed them and they said a .280 would have a rough idle. -
SATANSenior Member- 6782
ok so im going with a .473 lift and a 266 degree cam grind by schnider racing, ill keep you updated when i i get them back. -
TurboZkidSenior Member- 395
i read every thing on the cam degreeing SATAN. but now, what cams would be better than the schindler cams? since i was planning to buy these cams down the road. what other company would you suggest?
Well, the problem is the same as with everything else. You get what you pay for. The Schneider cams will run your car and unless you have a good set of cams with the same grind to compare to the Schneider shit cams, you may not even know that you just bought crap for cams.TurboZkid wrote: i read every thing on the cam degreeing SATAN. but now, what cams would be better than the schindler cams? since i was planning to buy these cams down the road. what other company would you suggest?
The only suggestion I have is either the ass rape JWT cams, or to go to a company like ISKY or someone like that, and have a custom set of cams made.
However, to be honest, I haven't come across a set of JWT cams to degree them to see how they stack up either. They could be just as bad, who knows.85 Z31 6.0 LSX turbo 766whp/792wtq
benz-techSenior Member- 311
Elgin cams in the bay area said they'd regrind me a set for around $350. whatever specs (within physical limits) you want. I'd trust them over Schneider these days.
