port matching intake plenum and intake manifold
mojoSenior Member- 209
would there be any gain in port matching the intake plenum and the intake manifold, i have a pathfinder plenum with a 60mm tb on it right now. -
Steve88tSenior Member- 1337
I doubt there is much difference between the plenum and lower intake. But I know the lower intake and heads often do not line up perfectly.http://z31performance.com/forum/viewtopic.php?f=5&t=147 -
SATANSenior Member- 6782
Anytime you match up your ports on anything, there is a gain to be had.mojo wrote: would there be any gain in port matching the intake plenum and the intake manifold, i have a pathfinder plenum with a 60mm tb on it right now.85 Z31 6.0 LSX turbo 766whp/792wtq
