Z31 pallnet rails and dsm injectors
  • Coffeygr
    Coffeygr
    Junior Member
    • 11
    So i was wondering if it was possible to use pallnet rails 11mm and -6an (http://www.z31online.com/item/Pallne…ector-Rails-68) with the dsm 450cc injectors instead of doing the 3000gt fuel rail swap, I’m looking to run a hx35 18psi on Nistune street tune and i wanna make sure i have enough fuel to play with without maxing my stock injectors out, also could i use the wastegate from the stock t3 on my hx35 at 18psi? Or would it only run 15psi thanks for any input
  • Augustus Maximus
    Augustus Maximus
    • 1739
    Run external wastegate
    Cha iro
    at least you gave it a whirl.
  • Timbo_021
    Timbo_021
    • 514
    Run the internal and see how you go, chances are you will have to go external but I guess nobody has tried it. 450cc you may get away with but better safe than sorry. Talking from experience, I maxed my 550s out at 24psi at around 4000rpm.
    Straya, +61
  • Coffeygr
    Coffeygr
    Junior Member
    • 11
    I’m going to run the external wastegate for safety and for the cool factor of the dump pipe under the car, and as far as i can read and research the rails will work with the dsm blue tops, are your using Nistune or stand alone ? My cars a daily so I’m not going to be pushing of 20psi lol
