IAC high boost pressure
 WilsonthesphereSenior Member WilsonthesphereSenior Member- 208
 IAC high boost pressureI have my IAC running into the valve cover and was wondering would is the IAC good enough to prevent higher boost 15-18 psi to leak out? Would it be better to run the IAC to the pressure side of my inter-cooler piping. I want to avoid putting a block off plate in its place.
 ThanksOwn:
 1993 Jeep Cherokee 4X4
 Owned:
 1995 Z32 2+0 NA Black
 1985 Z31 2+0 turbo Black
 1986 Z31 2+0 NA Red
 1988 Z31 2+2 NA Auto
 1984 Z31 2+0 turbo Brown
 1985 Z31 2+0 NA Black
 2003 Nissan frontier D22 supercharded vg33e 4x4
 Timbo_021Senior Member Timbo_021Senior Member- 514
