Just curious if any one has done the NA to turbo with the na (9.1) engine and euro cams. I will be running basically all the stock Nissan turbo parts including stock boost. Would the 9.1 compression with the euro cams cause any detonation issues without an intercooler?
Also what fuel should I expect to have to use with or without cams.
PS. I'm just considering the cams.
PSS. What would the rough hp be. I'm guessing just slightly more than 200.
Thanks
Thanks
