My Turbo LS 5.3 build
BLITZERKING1Member- 74
Posting this here in case anyone is interested. I'll be adding to the imgur album as I go. Car made 567whp on 93 octane pump gas
Basic Build specs:
5.3L LM7 out of a 2003 Tahoe, rings gapped
Summit Stage 2 turbo cam
PAC 1218 valve springs
241 heads off a Fbody
VS Racing billet 7875 Gen 1, 3" exhaust with Vibrant resonator
LS6 intake, Stock Truck TB
Z32 transmission with gforce adapter and flywheel
Z1 Motorsports Z32 TT performance 6 puck clutch
MS3 Goldbox with 24x harness
Snake eater 80lb Deka injectors
Walbro 450 fuel pump
EFI source 3bar MAP
Flipped truck manifolds into a hotside I made, Tial V44 wastegate
2.5" intercooler piping, 13"x24" intercooler, Greddy type RZ BOV
NGK TR6 spark plugs
Corvette accessory drive with ICT billet alternator bracket
Powered by Fund Solvaren.Last edited by BLITZERKING1; 11-05-2019, 01:52 PM.
- 2 likes
Nice build. how much boost were you running on the VG setup. Im curious because I was planning to run the S362 in the future but 480hp is short of my goals.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
2003 Nissan frontier D22 supercharded vg33e 4x4
