link1197 link1198 link1199 link1200 link1201 link1202 link1203 link1204 link1205 link1206 link1207 link1208 link1209 link1210 link1211 link1212 link1213 link1214 link1215 link1216 link1217 link1218 link1219 link1220 link1221 link1222 link1223 link1224 link1225 link1226 link1227 link1228 link1229 link1230 link1231 link1232 link1233 link1234 link1235 link1236 link1237 link1238 link1239 link1240 link1241 link1242 link1243 link1244 link1245 link1246 link1247 link1248 link1249 link1250 link1251 link1252 link1253 link1254 link1255 link1256 link1257 link1258 link1259 link1260 link1261 link1262 link1263 link1264 link1265 link1266 link1267 link1268 link1269 link1270 link1271 link1272 link1273 link1274 link1275 link1276 link1277 link1278 link1279 link1280 link1281 link1282 link1283 link1284 link1285 link1286 link1287 link1288 link1289 link1290 link1291 link1292 link1293 link1294 link1295 link1296 link1297 link1298 link1299 link1300 link1301 link1302 link1303 link1304 link1305 link1306 link1307 link1308 link1309 link1310 link1311 link1312 link1313 link1314 link1315 link1316 link1317 link1318 link1319 link1320 link1321 link1322 link1323 link1324 link1325 link1326 link1327 link1328 link1329
Ross MetalJacket Harmonic Balancer
  • dbruce
    dbruce
    • 258
    I have a Unorthodox Racing crank pulley that I haven't been able to use since I have all serpentine belts and I really am not up to swapping over to v belts…
    Found this at the Ausie forum :
    http://www.aus300zx.com/forum/showthread.php?t=251249
    Finally available special order to stat with lighter alloy and steel crank pulley WITH harmonic balancer
    ~600Au
    http://www.rossperformanceparts.com/met … cers.html#
    METAL JACKET Harmonic Balancers / Crank Pulley Dampers
    A World First In Balancer / Damper Design !! Encased Dampener Within Balancers
    Introducing a revolutionary development in torsional dampening technology. Utilising the ROSS Tuffbond original elastrometric bonding process to produce the ROSS Metaljacket® series harmonic balancers / crank pulley dampers.
    360 timing marks at 1° intervals
    Adjustable timing disc, for TDC accuracy
    Precision CNC machined 40 Tonne tensile alloy steel hub and vibration dampening ring
    Dampening ring and hub permanently bonded together on TWO axis by our exclusive Tuffbond elastrometric bonding process, ensuring maximum harmful vibrations are absorbed.
    balancer is anodized for durability and appearance
    Absorbs more damaging torsional harmonic vibrations
    Quicker engine acceleration
    Increases engine life
    Lifetime warranty, even for racing use - a world first!
    Never requires maintenance or rebuilding - ever!
    Rated to 1500 HP
    Encapsulated MetaL Jacket® design exceeds AN DRA and SF1 i8.1(USA) requirements
    Fits standard or modified engines
    Affordably priced
    NISSAN 306220 METAL JACKET HARMONIC BALANCER - VG-30
    NISSAN 306240 METAL JACKET HARMONIC BALANCER - nissan vg30 v6 10% u/d w/pump & alt
    http://z31.com/wiki/doku.php?do=export_ … c_balancer
    ===== Harmonic Balancer Information =====
    Because of the different years and engines, there were four different harmonic balancers used on the Z31's VG30 engines. Below is a chart to help determine which one you want to use.
    ^ Year ^ Engine ^ Aspiration ^ Part Number ^ PS Pulley ^ AC Pulley ^ H2O/Alt Pulley ^
    | 1984-1986 | A/B Series | non-turbo | 12303-V5020 | V-Belt | V-Belt | V-Belt |
    | 1984-1986 | A/B Series | turbo | 12303-V5320 | V-Belt | V-Belt | micro-V |
    | 1987 | A/B Series | all | 12303-F6100 | micro-V | micro-V | micro-V |
    | 1987-1989 | W Series | all | 12303-21V10 | micro-V | micro-V | micro-V |
    You can use the A/B series balancers on the W series crankshafts if you get the spacer from Nissan (p/n 12308-V5321).
    You should be able to use a W series balancer on an A/B series crankshaft if you get a slightly longer bolt with matching threads.
  • Taris Blue
    Taris Blue
    • 537
    I think and organized group buy may be in order with this one…it's something I've been looking for since about 2005. Nice find!
    2006 Scion tC (Wife Whip)
  • ARSpeed
    ARSpeed
    • 186
    Well i am at the point in my rebuild where this would be good.
    600.00 AUD = 557.013 USD
    Idk haven't bothered to look into lighter pulleys, underdrives, etc.
    Group buy. I'd be interested, if i have the funds. Waiting to see what bartco comes out with.
    +1 nice find
    Originally posted by michaelp
    The Industry is full of shit. Americans are morons and follow band wagons.
    Illusions of Oasis. REPENT
  • zmech
    zmech
    • 964
    0
  • tcfs
    tcfs
    • 225
    #5
    I'm pretty sure that pulley is for a VG30DE/DETT.
    Reasons for saying this:
    1. On the site, it is listed simply as for the VG30. This usually means the VG30DE/DETT because it is more popular and has a larger aftermarket.
    2. The diameter of the alt/waterpump and ac belt lands look be the same size in the picture. On stock VG30E/ET w-series crank pulleys the alt/waterpump pulley land is noticeably larger in diameter.
    3. All the guys on that forum have pictures of Z32's as avatars. So more than likely they all have Z32's and are looking at a crank pulley for a Z32. I didn't read all the way through the discussion on the forum, but I believe the forum is for Z32's.
    Done.
    Shiro #93
    Mods: A/C Removal, Custom Lightweight W-series crank pulley, K&N Air Filter, Electric Fan, EGR/AIV/CC removal
  • dbruce
    dbruce
    • 258
    #6
    tcfs wrote: I'm pretty sure that pulley is for a VG30DE/DETT.
    … Done.
    If it sounds to good to be true… prob is… they do make dor the RB- series
    Like the ATI damper spec's VG30 but it's VG30DE:
    http://www.importpartspro.com/aticrpudani3.html
    Other possibilties:
    BHJ make the L-series dampers for Robello - no VG30E damper:
    http://www.bhjdynamics.com/index.php?ma … hs2s668031
    Sorry for false hopes…
  • ZFast88Z
    ZFast88Z
    • 1882
    #7
    zmech wrote: Are you serious!
    Why do you want a pretty pulley for that type of funding???
    Because its SFI approved, and some of us NEED to find an SFI approved harmonic balancer/crank pulley....Or pay off the track inspector.
    The bullshit stops, when the GREEN light drops.
  • jn1cz
    jn1cz
    • 1520
    #8
    [quote]dbruce wrote:
    … Done.
    Other possibilties:
    One of the guys from BHJ posts at HZ. I PMed him about a z31 damper but he never responded. I posted in the Bartco thread at z31.com and he didn't respond either. Fuck 'em…do it like z31 parts have always been done..do it yourself or go to a good automotive machine shop and hand over a z31 damper and your credit card and tell them what you want.
  • Careless
    Careless
    • 13279
    #9
    that is definitely a VG30DETT balancer. look at the spacing of the pulley sections and the number of ribs per pulley, and compare to other vg30dett pulleys.
    This works with the VG33 crank snout diameter.
  • SATAN
    SATAN
    • 6782
    #10
    There is just one problem with that. The only reason for getting this is because they are SFI approved. A regular machinist cannot sfi approve anything.
  • jn1cz
    jn1cz
    • 1520
    #11
    And a company like BHJ can ? I thought only the SFI foundation could give SFI certification. Seems like you or the machine shop could apply for certification. I don't think that most z31ers are concerned with SFI certification anyway. You and ZFast88Z maybe.
    All I wanted was a lighter damper w/ trigger wheel provisions. And that didn't have chips missing, cracks etc, I could have bought a new Nissan damper and had it machined for a trigger wheel but the price would have been close to the dampers posted and it wouldn't have been any lighter.
  • MachZ
    MachZ
    • 386
    #12
    I believe ATI does have a damper that would be compatible for our smaller crank snouts. If you loot at this page: http://www.atiracing.com/products/dampe … nissan.htm you'll see at the bottom they list V6 engines with one having a snout diameter of .980", which I believe will work on the smaller VG30E snouts. Someone might give them a call and see if they can work something up for you.
  • Tech@EPR
    Tech@EPR
    • 551
    #13
    The ATI damper for the VG30 is for the DE/DETT models. I worked with ATI in getting those done and the project rolled over to BDE out in Washington. He came out with the first batch. They are pricey but the benefits are quite substantial. I can have ATI make us true VG30E dampers but they require an order of 10 to get any type of discount. I can send them a crank for them to build off of as well.
    Nissan Race Engine Machine Shop
    Dedicated to VG performance and design http://www.epracing.net
  • 260zturbo
    260zturbo
    • 169
    #14
    this would be interesting guessing they would have to make one for the a/b and w series
    07 Nissan Frontier 4.0 NISMO--SOLD
    84 Ranger 4x4 2.8 v6
    84 AE---Future Beast IN THE WORKS http://z31performance.com/showthread…lmost-stock-ae :-)
    74 260zT project vg30et---SOLD
    2013 Dodge Ram 1500 HEMI Big Horn (DD)
    2000 Suzuki SV650S
  • MachZ
    MachZ
    • 386
    #15
    Tech@EPR wrote: The ATI damper for the VG30 is for the DE/DETT models
    Not the VG30 one, its under that listed as V6 with .980 crank snout.
