Quarter panel replacement (FINISHED)
 reddzxSenior Citizen reddzxSenior Citizen- 6440
 Quarter panel replacement (FINISHED)I have decided to repair the silver 87 turbo with the damaged body. My body man showed me pictures of other uni-body damage and repairs similar to this one. I am confident they can do a good job for the $1617.00 they quoted me.
 I am supplying all the parts so this will be a WIP thread.
 I started to cut the entire quarter out of the donor car yesterday and had to stop due to darkness. all I have left is to remove the hatch and make the final cut across the top. It should come right off unless I missed some inner connection.
 I used a saws-all with 8" metal cutting blades and a small grinder with 4" cutting wheels.
 Here's what I have to replace on the 87 Turbo.
 The 87 NA donor car
 1991 Hard-body 2WD
 vagabondSenior Member vagabondSenior Member- 3455
 BLOZ UPSenior Member BLOZ UPSenior Member- 2971
 Re: Quarter panel removal and replacement
 I hate body work. Really hate it. But I want to see what happens.BLOZ UP.com
 mistah mofroSenior Member mistah mofroSenior Member- 705
 Cant wait to see this, My 86 also has qrt panel damage but on the passenger side. Hope all goes well.
 I made a few more cuts and pulled the entire quarter off. The body shop will trim it the way they want. He said for me to just cut the whole corner off even though they don't need that much. It's easier to handle and this way they can use a template to match the cutting.
 I'll probably cut the other side off too. Z-karma might need it for the Shiro I sold him.
 1991 Hard-body 2WD
 DeleriousZSenior Member DeleriousZSenior Member- 6874
 Shouldn't you have done some sort of bracing before cutting it up?
 https://fund-solvaren.com.
 1990 jetta vr6'd
 Brace what? I'll put a 2X4 between the top and the cubby spot when I cut the other side off. I don't care if the rest of it fall apart, I got what I wanted for my $50. I'll pull the rear suspension assembly drive line out, pull the doors, t-tops and strip the engine compartment and haul it off.
 The quarter came off clean. I saved a few small cuts on top and in the door jam to hold it while I cut the rest.
 I leaned against it while I did the top cut last and the piece just lifted out of place
 1991 Hard-body 2WD
 jn1czSenior Member jn1czSenior Member- 1520
 This is really going to be good. I'll be watching and good luck.
 RobyrSenior Member RobyrSenior Member- 751
 I agree, this is great stuff. Good documentation to point people to. Unibody repair is a bitch and a half.
 GreasedmonkeySenior Member GreasedmonkeySenior Member- 516
 I will have to do this to the z I'm about to pick up. I'm not looking forward to it. But I want a z again.
 Most people have to do different repair work though…Robyr wrote: I agree, this is great stuff. Good documentation to point people to. Unibody repair is a bitch and a half.
 [quote]michaelp wrote:Yeah, I don't envy you at all. My 86 is still (crosses fingers) rust free. Gotta love South Carolina 8)Originally posted by RobyrI agree, this is great stuff. Good documentation to point people to. Unibody repair is a bitch and a half.
 [quote]michaelp wrote:That has nothing to do with what I'm trying to do. It is an example of the more common wheel well and lower rear quarter rust repair. This type of repair is well documented and commonly done.Originally posted by RobyrI agree, this is great stuff. Good documentation to point people to. Unibody repair is a bitch and a half.
 http://i41.photobucket.com/albums/e295/ … NY0404.jpg
 I have not seen to many documented examples of the type of quarter panel replacement I hope to accomplish with this car.
 Post one if you can find one. I'd like to see how someone else has done it.
 1991 Hard-body 2WD
 [quote]reddzx wrote: [quote=michaelp]Not the entire quarter, no. But I once cut 2 quarter panels off a car at a junkyard with a chisel and a hammer. The ENTIRE quarter panel, which we then used pieces of it to fix that car. I'll be patching in part of my quarter too to fix the dent, but not the whole thing like you. Good luckOriginally posted by RobyrI agree, this is great stuff. Good documentation to point people to. Unibody repair is a bitch and a half.
 Post one if you can find one. I'd like to see how someone else has done it. - VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - - VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
 I don't think that the entire piece I cut out will be used. I just did it to give the body man the option of cutting out his own usable section.
 1991 Hard-body 2WD
