Adjustable suspension interchange
  • Dave@SBC
    Dave@SBC
    • 494
    Yeah, another adj sus question. I've been doing some searching with no result. Fig the fastest way to get a straight answer is to ask.
    I have an 84 GLL and an 84 turbo parts car. Since it's free and I'm cheap, I'd like to put the adjustable suspension on my GLL as well as the 5 lug setup. I don't think I'll have much issue of making the suspension physically fit, but the wiring… do I need to transfer over the wiring harness?
    Dave
    Z31P sponsor
    800-988-4345 ext: 114
    http://www.DXDRacingclutches.com
    90 Z32 Base 5spd, 05 Z33 Touring 6spd.
    SOLD- 84 Z31 NA2T GLL 5spd
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    Adjustment of the electronic shocks is via a switch located on the center console (3-settings .. LOL, I don't even touch it anymore .. "S" .. "M"(?) … "F"
    So my guess is "yes" .. you'll need the harness from the 84T to make it work.
    '84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
    Originally posted by maronee
    PS - by the way your Z31's famous here in japan, dude!!
  • Dave@SBC
    Dave@SBC
    • 494
    Thanks!
    Dave
    Z31P sponsor
  • MADMIKE
    MADMIKE
    • 1533
    do you still have a functioning set of Adjustable Shocks, or is the light just blinking like every other one I have seen.
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • inqui-Z-tor
    inqui-Z-tor
    • 9020
    #5
    MADMIKE wrote: do you still have a functioning set of Adjustable Shocks, or is the light just blinking like every other one I have seen.
    LOL .. I guess I exagerated (sp) a bit. I do mess with mine from time to time, when I'm on the road .. heading to an event. Mine work just fine ..
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #6
    I have two cars that they work in and an extra set of adj. rear shocks.
    1991 Hard-body 2WD
  • Dave@SBC
    Dave@SBC
    • 494
    #7
    This is Jason @ Z31parts old ice racing car. He swears they work like a champ and one of the fronts has a new replacement. Keep in mind, your old junk becomes my treasure
    Dave
    Z31P sponsor
  • MADMIKE
    MADMIKE
    • 1533
    #8
    :-D
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
  • Blown-N-Boosted
    Blown-N-Boosted
    • 430
    #9
    The main body harness would have to be changed. Which means the car basically has to be completely stripped including all interior, dash, plus everything thats behnid the dash. If it was me I would set the shocks to stiff then swap the 5 lug stuff over and just keep it like that. More than likely even if the suspension does work it will need to be serviced in the future at some point anyways and instead of installing old used struts again you'll probably just go with aftermarket. Have you checked to see if the shock light moves through the settings or flashes? I have quite a bit of adjustable shock parts if you need any. I also have regular struts and shocks(good/used and new)Just swing through or let me know.
  • Benedict
    Benedict
    • 915
    #10
    you do not need to move the entire harness. (although some would see that as the easier route)
    fsm
    fa-18
    find, isolate, and remove this circuit from your donor Z and wire it into the one receiving the adjustable shocks
    I wrap my paper weights in glitter.
