The Z31 Wheel Show - many fine examples!
 weswazJunior Member weswazJunior Member- 3
 Thanks for the suggestion on setting up a member ride thread. I'll do that.Rick88ss wrote:
 Woah! That Z looks super clean. Post up more pics and put up a member ride thread. That Z looks super clean. Post up more pics and put up a member ride thread.
 Still looking for thoughts on a finding a chrome hub… you can see the driver side rear is missing one.
 I don't know who's Z31 this is but this the wheels I'm rockin.
 Staggered Z32TT wheels 1.25 front and 1.5 inch spacer rear dropped on STsprings.Cha iro
 at least you gave it a whirl.
 rbz31Junior Member rbz31Junior Member- 2
 my 300zr 18x10+12 & 18x11+20 255/35 & 285/30
 84 zenki 19x8.5+18 & 19x9.5+13 235/35 & 265/30
 jon.87 300zr vg30de as standard, 88 200zr with rb30et, 84 zenki 200zr replica build with rb25det
 adamvann3Senior Member adamvann3Senior Member- 4160
 Need more pictures of this car. Im digging it.rbz31 wrote: my 300zr 18x10+12 & 18x11+20 255/35 & 285/30
 jon.86na - BlueZ
 85t - Mr Tickles
 badboyz31Senior Member badboyz31Senior Member- 2403
 XXR 521 18x10 +12 all around
 still need to put the 10mm spacer on the rear, roll and possibly pull in the rear. Front just needs more low
 Edit: Suspension setup in rear is s13, with stance coils and SPL control arms
 Front setup is just stance coils with the camber plates at the top1uz Swapped, lowered, flaked out '86 z31
 Custom vg30et tube chassis drift exocet project
 DeleriousZSenior Member DeleriousZSenior Member- 6874
 Should mention your suspension setup too, cause on z31 rear suspension that'll sit differently.
 1990 jetta vr6'd
 done!DeleriousZ wrote: Should mention your suspension setup too, cause on z31 rear suspension that'll sit differently.1uz Swapped, lowered, flaked out '86 z31
 Post the pictures and information into this thread, its much more relevant. I am not sure why this one was even stickied.
 viewtopic.php?f=2&t=17576&hilit=wheel86na - BlueZ
 85t - Mr Tickles
 will do1uz Swapped, lowered, flaked out '86 z31
 reddzxSenior Citizen reddzxSenior Citizen- 6440
 1991 Hard-body 2WD
 LA KINGSMember LA KINGSMember- 43
 Using oem 350z tire specs the 350z Anniversary wheels with +30 offset up front and +33 in the rear will not clear the strut and the center caps wont fit, the tire will still turn but you will see that its rubbing against the strut. However you choose to do it is up to you but you WILL need to space the wheels. Given the wheel still turns the space is very minimal so keep that in mind. You will also need open ended lug nuts if you go with the hubcentric route I chose.
 I absolutely reccomend hubcentric adapters over sketchy wheel spacers.
 What I used:
 Hubcentric wheel adapters that are 1 1/2" thick with 5x114.3 to 5x114.3 and a set of open ended lug nuts. Here are some pictures of the adapters and fitment on stock suspension.
 hosmerJunior Member hosmerJunior Member- 6
 Got my V8 swap up and running (well) and threw these on the car
 Volk LE37
 18x8.5/9.5 +22
 245/40 fronts and 275/40 rears
 TWA88TMember TWA88TMember- 84
 Is there a new wheel show? All the links on here and my old ones are all dead.... Need new wheels this year.Who needs new car's, Nissan had it right 30 years ago!!!
 86na - BlueZ
 85t - Mr Tickles
