Hub bolts. Stock, new, replace?
KennedySenior Member- 1158
I have been looking specs for stock Z31 hub bolts. Haven't found any.
Have anyone measured those?
Is there direct replacement that actually are same size serration(?) as Z31?
Or if i want to change bolts to new. Do i drill hole little bigger and hammer those Z32 ones in?
Looks like Nismo ones are only Z32 and few other
A - B - C - D - E - Size - Serration
50 - 15 - 10 - 19 - 5 - M12x1.25 - 14.3x36TJukka Kivinen - Europe / Finland - '88 Turbo 2+2 Targa
DeleriousZSenior Member- 6874
s13 studs will work just fine. all you need to make sure of is that the knurl diameter is 13mm.
1990 jetta vr6'd -
those are the correct sizes, but $$$$$. check out circuit sports or ichiba for cheaper ones.
one thing of note with extended studs, the rears can be a pain to do if you haven't pulled the dust shield off, and are trying to replace the studs with the hubs on the car.
1990 jetta vr6'd -
http://cgi.ebay.com/ebaymotors/ICHIB…-/140484927501
http://enjukuracing.com/circuit-spor…ds-p-9209.html
Yeah.. little bit cheaper
But still if anyone have exact measurements on Z31's bolt..Jukka Kivinen - Europe / Finland - '88 Turbo 2+2 Targa
a 42.0mm
b 15.4mm
c 7.7mm
d 18.5mm
e 5.5mm
measurements taken off a stock used stud so dims are probably +- 0.3mm
1990 jetta vr6'd -
Dave88SSMember- 83
I have the studs that come with Ichiba spacers (say fit 87-96 300ZX or something similar) I had to get my front hubs machined to fit the larger knurl. I don't have access to anything I'd trust to put perpendicular holes in a hub.Kennedy wrote:
Or if i want to change bolts to new. Do i drill hole little bigger and hammer those Z32 ones in?*****************************
1988 300ZX Turbo SS
2000 BMW 323Ci
2003 BMW 325XiT -
[quote]Dave88SS wrote:That was probably the s14 style (z32 style too??) of stud with the larger knurl diameter. The s13 stud (and s14 rear) is a direct replacement for the z31's stud.Originally posted by KennedyOr if i want to change bolts to new. Do i drill hole little bigger and hammer those Z32 ones in?
1990 jetta vr6'd -
blak300zxSenior Member- 332
adamvann3Senior Member- 4160
This is all you need to know. They are everywhere and work no problemDeleriousZ wrote: s13 studs will work just fine. all you need to make sure of is that the knurl diameter is 13mm.86na - BlueZ
85t - Mr Tickles -
Dave88SSMember- 83
[quote]DeleriousZ wrote: [quote=Dave88SS]I bought mine from Protuninglab.com. I asked if I could get the ICHIBA 5 lug spacer with studs from the S13 kit and they said they're the same part number. My confidence in ICHIBA and/or Protuninglab is rather low.Originally posted by KennedyOr if i want to change bolts to new. Do i drill hole little bigger and hammer those Z32 ones in?
That was probably the s14 style (z32 style too??) of stud with the larger knurl diameter. The s13 stud (and s14 rear) is a direct replacement for the z31's stud.*****************************
1988 300ZX Turbo SS
2000 BMW 323Ci
2003 BMW 325XiT -
I ordered my spacers from tougefactory, and told them it was for a 5 bolt 240sx s13. I could grab the pn off the box of anyone would like, because it was exactly what I needed!
1990 jetta vr6'd -
I use 10mm slip ons for for a 350z. As long as its the nissan bore, 66.7mm, everything is gravy.DeleriousZ wrote: I ordered my spacers from tougefactory, and told them it was for a 5 bolt 240sx s13. I could grab the pn off the box of anyone would like, because it was exactly what I needed!86na - BlueZ
85t - Mr Tickles -
66.1? lol
1990 jetta vr6'd -
I didnt remember. Most of the time they either label them 66 or 67mmDeleriousZ wrote: 66.1? lol86na - BlueZ
85t - Mr Tickles
