Brake Upgrade Thread
adamvann3Senior Member- 4160
Decided to go with alkaline cleaner to clean out the passages, as well as avoid messing with the piston seat's surface. Other than a quick solvent clean job to remove grease, this bitches were tossed in rust, chipping paint, ect… right into the cleaner and came out looking good. Chemical cleaning is the way to go.
Powder coated, along with bolt heads
Polished the pistons to ensure a good seal and seamless movement. Rebuilt with z1 kit.
Old 86na BZF installed goodness
New 350z Track + z32tt
Notes:
~Use early grease seals in late turbo hubs with zenki dust shields. Zero clearance issues.
~No need to trim the dust shield with the caliper adapter86na - BlueZ
85t - Mr Tickles -
FLAZH007Senior Member- 132
Alright, Ive read all 8 pages of this thread and itâs very interesting but one problem. I havenât seen one person on here use z32 30mm calipers on '87 OEM wheels. Because Iâm using '87 hubs and all, 17 size washers for alignment, Brembo z32 rotors still the OEM size, and itâs still not clearing the wheel. It needs some kind of spacer to push the wheel out very little so it wonât rub :-?1985-5 speed swap with '87 suspension.
1987 turbo-parts car,engine rebulid in process.
MuhKaydenZSenior Member- 657
I used the 30 mm z32 brakes and rotors and I had to use 86t wheels to clear I tried 85t wheels and they did not clear I later had to get longer studs and a small spacer to get my other wheels to work
Longer Studs I purchased them from ebay link below
http://www.ebay.com/itm/330629773859?ss … 1497.l2649
After with a small spacer
Replaced my BMC with one from a Z32 link below made it plug and play
http://www.ebay.com/itm/250810617597?ss … 1497.l2649
Click here to view my Stanced VG33ET Build thread / Click here to view my Feed Back thread
What size did you use?1985-5 speed swap with '87 suspension.
I had some 10MM spacers so I threw them on and they worked greatClick here to view my Stanced VG33ET Build thread / Click here to view my Feed Back thread
Ok so heres mines....
Have everything 87 hubs and all
5/16th spacer.
Made my own o rings from some similar size rubber o rings I got from Ace Hardware.But I did get the compleat rebulid kit.
30mm from 91 z32TT
Still need longer studs…
This is what happens when you dont use some kind of spacer on 87T OEM wheels
NissanEggSenior Member- 5220
87T+ wheels have 10mm less offset that's why they rub the calipers. 84AE/86T wheels have +20mm offset. 87T+ have +30mm offset.
Yep found that out the hard way.But its ok,I didnt scrap my calipers too bad and you cant even see them.Once I get some Mustang Cobra wheels Ill just repaint them a little.NissanEgg wrote: 87T+ wheels have 10mm less offset that's why they rub the calipers. 84AE/86T wheels have +20mm offset. 87T+ have +30mm offset.1985-5 speed swap with '87 suspension.
coryz31Senior Member- 116
cjlewisz31Senior Member- 345
what size rotor do the gts use? im only asking because i have a set front and rear of a gtr non-V spec and i know they wont clear for sure.coryz31 wrote: I used r33 gts calipers on stock rotors with 87t wheels, and had no rubbing problems. -
[quote]cjlewisz31 wrote:http://carfish.net16.net/brakes.htmlOriginally posted by coryz31I used r33 gts calipers on stock rotors with 87t wheels, and had no rubbing problems.what size rotor do the gts use? im only asking because i have a set front and rear of a gtr non-V spec and i know they wont clear for sure. -
[quote]G-E wrote: [quote=cjlewisz31]thanx for the link bud. my rotors are 296x32 so im guessing if your fit then so should mine.Originally posted by coryz31I used r33 gts calipers on stock rotors with 87t wheels, and had no rubbing problems.what size rotor do the gts use? im only asking because i have a set front and rear of a gtr non-V spec and i know they wont clear for sure.http://carfish.net16.net/brakes.html -
I did need 8mm (minimum) spacer for the 17" rims I have, so I expect something similar for stock 87t rims, the caliper however needs less offsetting from the mount, mine needed 4-4.5mm to center on the rotorcjlewisz31 wrote: thanx for the link bud. my rotors are 296x32 so im guessing if your fit then so should mine.
If you used narrower rotors (z32) and spaced the inner pad out more (lotsa shims, custom plate etc), you could get more rim clearance by keeping the caliper closer to the mount -
thanx for that. i will be using s13 knuckles so it should, key word "should", clear my wheels. i have an old set of 5 lug Rikens with the same wheel offset as the 88t. worst case ill need a small spacer as you mentioned. -
The hub you use doesn't change the caliper clearance, the brake rotor dictates where everything sits, on the S-chassis you just don't have to space the caliper out as I recallcjlewisz31 wrote: thanx for that. i will be using s13 knuckles so it should, key word "should", clear my wheels. i have an old set of 5 lug Rikens with the same wheel offset as the 88t. worst case ill need a small spacer as you mentioned.
My old chassis is going to get a big brake kit of some kind, and I think I'll be using lathed non-turbo hubs for extra offset, which will allow room for a nice bracket for any kind of caliper/rotor
