Damper settings on your coilovers
  • frostvectron
    frostvectron
    • 1044
    Welp, got my powertrix coilovers on my car!
    I am curious to know what everybody is running for their damper settings. Right now I am on 8F/8R just for testing purposes (15-way adjustable).
    What is everyone running (and for what application?). Anyone have any good info on how to identify a good setup?
    Powertrix recommendations for the Z32:
    Street/Drag 1 front - 1 rear
    Autocross 3 front – 5-6 rear
    Road Coarse Track 5 front – 5-6 rear
    And some general guidelines from STANCE:
    Stance coilovers are 15way adjustable which can be felt with each click. Unlike other brands, our dampers offer wide range of adjustment so you do not need to make huge changes to feel the difference. We recommend adjusting 2 clicks at a time.
    If this is your first time adjusting your coilover we recommend starting out at "0" setting. Turn the adjustment clicker clockwise until it stops, this is your full stiff. Now, turn back 8 clicks from full stiff, this is your "0" setting. This is your "sweet spot". You can now adjust 2 clicks at a time to adjust to your personal preference for street driving.
    We also recommend starting out at 0 setting even for track driving and adjusting 2 clicks at a time. If the vehicle tends to understeer into corners, you can increase the damping force in the rears and decrease damping on the fronts. If the vehicle is oversteering into corners, you can increase damping force in the fronts and decrease in the rears. This is a very basic way to tune your suspension. You can also use ride height, chassis balance, tire pressure, tire compound and aerodynamics to tune your vehicle for ultimate traction.
    I'll be driving at a "test and tune" event for autocross in a week and a half. I hope to go through a variety of settings and try to find what works well. Would be cool to see what everyone is running on so I can start building up some intuition though!
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • adamvann3
    adamvann3
    • 4160
    Im on 9/10k I believe and running 3/4 stiff front and back. Rears I still play with front time to time as it depends on wheel and tire setup. Fronts I never touch.
    86na - BlueZ
    85t - Mr Tickles
  • frostvectron
    frostvectron
    • 1044
    Hmm… okay, did some testing today. Tested autox with Hankook 225/50/16 V12 EVOs (40 psi front / 37 psi rear) and and old set of Bridgestone Pole Position S-03's (37 psi front, 36 psi rear). Also, I'm on 9kg/mm front and 7kg/mm rear.
    Started 8/8 (out of 15) as the starting point.
    I tried 8/6 but I didn't like it. It felt neutral but I felt like the car wasn't rotating very nicely.
    I went to 8/10 and this set-up was very fun to drive. It rotated easily and had good turn in.
    I then tried some other junk later in the day. I tried 10/10 and 10/12 but I didn't like it as much as the 8/10.
    I tried a 6/8 and 6/7 which felt pretty good for these less grippy tires. When I run the Direzza Z1's tomorrow I'll try 6/8 first and maybe try the 8/10 again.
    I get some "wheel hop" from the rear around some corners. What does this mean for damping? I am thinking the inner rear is lifting a bit. I was lower on fuel that usual, so hopefully this helps keep the rear down. I also lowered the car in the rear by 5mm to try and get it more planted.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    This is where separate rebound adjustment comes in handy
    Since you've already got a feel for the damping, why not play with swaybar sizing now?
  • frostvectron
    frostvectron
    • 1044
    #5
    I'm running the 1" sways on front and rear at the moment. I think they are old ST ones but not sure (gray in color). How do you place with sway sizing? Fabbing or trying combinations of factory/aftermarket ones?
    I ran the Direzza Z1's today at 31/30 psi front/rear. I did 8/10 on the coilovers and it felt fantastic!
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    #6
    Think of it this way, your tires (whatever you run) have a maximum amount of grip or capability, the higher that maximum, the more load you can transfer from the chassis to the tires.... overloading the tires just makes them overheat, wear faster, slide more etc
    By load I mean: every chassis has give, every bushing deforming, every frame rail twisting, every spring compressing -- that give absorbs some of the ultimate load of whatever you are trying to do, each time you strengthen one area, you move more load to all the remaining areas, and so on, until you reach the tires, they are the last stop
    Since we all don't have professional race teams with fea analysis and unlimited modification budgets, realistically we are only going to play with a few aspects of the chassis -- minor ones like springs/shocks/bushings, to major ones like strut bars/frame connectors/roll cage -- and they'll likely all be done at one time
    Anyway to answer your question, the stock swaybars for various years already vary from 21-24mm in the rear, and are easy to obtain, probably for very little cost, probably your only real option… especially since we don't have adjustable rear aftermarket bars available (unless you magically find some koni kit like jason did)
    I think in your situation any stock rear bar will be good enough to test, see if softening it helps or hurts the balance of the car, if it helps, then you can explore other sizes in the range, or fab up some custom clamp/endlink to allow adjusting your bar stiffness
    BTW welding longer tabs to the end of the swaybar is acceptable too, it won't ruin the elastic section between the mounts, and there isn't that much stress on them (be very surprised if the stress exceeded 300lbs)
  • 88Turbozx
    88Turbozx
    • 318
    #7
    I'm on 9k 7k Powertrix coils and it seems that 8 front and 7 rear is perfect for gripping with 265/35/18s all around on continentals with the rear slightly lower than the front. I had the same damping before I balded out my Pilot sport PS2 255/35/18F 285/35/18R and it probably could have been a little stiffer for those tires. I found my "sweet spot" for ride height is 3 1/2 inches from the top of the lower spring mount (ring) to the bottom of the coilover ring that tightens to the bottom mount in the front, and 1 3/4 inches between those in the rear.
    Dont give up, build your dream Z
  • badboyz31
    badboyz31
    • 2403
    #8
    I'm on Stance Pro SS-D coils, with 12k springs all around, and have mine 10 clicks to the hard side on both front and rear. This is on 15way adjustable's also, its stiff as hell on the street but fun as hell on the track
    1uz Swapped, lowered, flaked out '86 z31
    Custom vg30et tube chassis drift exocet project
  • michaelp
    michaelp
    • 9384
    #9
    I'm running 9 towards the hard side with my Powertrix coils with 9k/7k springs…I like it.
  • frostvectron
    frostvectron
    • 1044
    #10
    Okay… after putting some more autox's on the coilovers, I think I am running too stiff on damping.
    8/10 and 8/8 make the car really harsh over bumps on the track. On corner entry it isn't so bad--just makes things a little dicey due to instability during trail braking. On corner exits it hurts quite a bit because I am losing traction when trying to accelerate after the apex. Maybe I should have done the 8k/6k spring rate combo instead of the 9k/7k.
    I will try the next event with less damping and see what happens.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    #11
    Unfortunately the trail braking issue is most likely your semi-trailing arms doing nasty toe changes on you…
    Have you swapped swaybars and tried playing with damping settings again?
  • frostvectron
    frostvectron
    • 1044
    #12
    I have not swapped sways around yet.
    I am thinking of raising the car a little bit and reducing the damping. Today I drove a little on the street with the rears at 5 and the ride felt a lot smoother.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    #13
    You can try the reverse too, stiffer rebound damping in the back, and less swaybar… possibly even lowering rear ride height could help? The closer you can keep the trailing arms to level during the turn (including the droop when you shift weight forward), the less your toe will change
    BTW are you finding it happening on lefts and rights? You could bias the swaybar…
  • frostvectron
    frostvectron
    • 1044
    #14
    Lowering rear ride height? I was wondering if I had gone "too low" and pushed my alignment too far from spec.
    I am finding it on both left and right handers. Honestly the suspension works great if the surface is really smooth. It is just that some parts of the course I run at has rough patches with bumps. The car doesn't appear to handle badly because of the suspension itself, but more because it isn't coping with the poor surfaces very well. Corners on smooth parts of the course are no problem.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    #15
    If you have to go soft, go soft… you might wanna back down on tire pressure a tad too as you'll be putting less load on them
