Any tricks to remove front strut inserts???
chipo280zJunior Member- 10
Hello i have a 1984 300zx turbo with adjustable suspension. I got eibachs and tokico illuminas for my car, and i already did the rear and now moving to the front. I got the whole thing out but i cant seem to be able to remove the strut insert. Also no fluid came out of it, it seems to be all dry in there. Any tips would be greatly appreciated. -
reddzxSenior Citizen- 6440
ad some trans fluid, let set for a while then tap strut housings with a plastic/rubber hammer
1991 Hard-body 2WD
cool thank you it has been soaking in wd40 ill put some atf and try it again. I will let you know guys if it worked. THanks -
Try to pry out the o-ring from the strut once the gland nut is off… I find the turbo ones are much tighter -
Ah yes, the O-ring will prevent it from coming out. Good call.
1991 Hard-body 2WD
Axel kainModerator- 1221
best I have found- once spring, etc, and gland nut are off, lock strut shaft in a vise, with strut tube below, then get a nice big hammer, and knock on the lower section of the tube/knuckle to free it down from the strut! sometimes they get rusty inside, and stick together!Damn dirty angels....these cars!
sigpic -
ok so i tryed different methods. What actually seems to work better with simple tools is using a 14mm wrench and put it between the strut nut and the actual cartridge and then with a hammer start tapping until it frees up. Probably the best way would have been with a slide hammer but i dont have one at my house. Putting some atf on it to lubricate seem to help a lot too. Thanks for your reply guys.
