anyone ever shorten and rethread a strut shaft?
What did they do?Rahlude92;346135 wrote: I know im thread jacking here, but ground control has gone bat shit crazy with the modification to the front strut.. -
Rahlude92Senior Member- 266
To modify the front strut housing $1049 fronts only....for a little bit extra....full set of stance....-89 300zx - recent- 88 turbo motor HX35w ported custom internal wastegate build with roastin300 custom adaptor flange+feed line , FMIC 2.5" piping TINY INTERCOOLER RESTRICTIVE PIPING, 480cc injectors, Custom Maxima plenum, rommulator moderate tune, Z32 maf upgrade, J30 vlsd swap (shimmed), Eibach progressive rate springs, Tokico illuminas (rear), tokico blue (front), poly bushings, short shifter mod. @18psi 323 whp 387 ftlbs.
-Previous- NA2T on 12-13 lbs 243 hp 255tq (exhaust leak) -
707Redz31Senior Member- 375
I actually called them a couple months ago about this and they said they don't do it. Do you know who talk to there? Cause no one i talked to seemed to know anything about this as a service from them.G-E;336824 wrote: Ground control does this too if you ask… -
No, I did hear a few people using other cars up here did, but I never had any intention of going gc anyway
… it's beginning to sound like they don't want our business anyway : -
Yup. Do you know of any coil over sleeves that would work? And whether its for the s13 or 280zx?-89 300zx - recent- 88 turbo motor HX35w ported custom internal wastegate build with roastin300 custom adaptor flange+feed line , FMIC 2.5" piping TINY INTERCOOLER RESTRICTIVE PIPING, 480cc injectors, Custom Maxima plenum, rommulator moderate tune, Z32 maf upgrade, J30 vlsd swap (shimmed), Eibach progressive rate springs, Tokico illuminas (rear), tokico blue (front), poly bushings, short shifter mod. @18psi 323 whp 387 ftlbs.
DeleriousZSenior Member- 6874
madness?G-E;346154 wrote: That's madness
1990 jetta vr6'd -
lol can anyone pitch in the info?-89 300zx - recent- 88 turbo motor HX35w ported custom internal wastegate build with roastin300 custom adaptor flange+feed line , FMIC 2.5" piping TINY INTERCOOLER RESTRICTIVE PIPING, 480cc injectors, Custom Maxima plenum, rommulator moderate tune, Z32 maf upgrade, J30 vlsd swap (shimmed), Eibach progressive rate springs, Tokico illuminas (rear), tokico blue (front), poly bushings, short shifter mod. @18psi 323 whp 387 ftlbs.
