Tires 18 … is this to big ?
mammutMember- 80
hello,
i have a question
i have a 89`z31 turbo (EU Spec, FS5R30A)
stock tire are 225/50 16"
i will swap my rims from
front: 235/45 17"
back 255/40 17"
to
i am going now to but
front: 225/45 18"
back: 245/45 18"
will this fit ? my car is a bit lower than stock
and how is it with the speedo ?
there should be a small difference also in stock ?
does anyone have experience with it ?
what is the maximum tire rollout to get close as possible to the speedo ?
thank u for u helpmy sunset Z youtu.be/HVp6CFcrx2U
making of video youtu.be/9BN8p-DuVuo -
DeleriousZSenior Member- 6874
Yes, 225/45 245/45 is too large. Go for 225/40 245/40 for 18's.
1990 jetta vr6'd -
mammutMember- 80
i know that kind of calculator
this tires are stock for z33
no one with experience or
or know how much the speedo is wrong with stock ?my sunset Z youtu.be/HVp6CFcrx2U
Did you even go to the link? I'm assuming you didn't since you're asking this.mammut;337548 wrote: i know that kind of calculator
or know how much the speedo is wrong with stock ?Prius… because Pretentious wouldn't fit across the back of the car…
My 1986 Turbo Build -
1990 jetta vr6'd -
mammutMember- 80
i get the wheels with this tires from a friend .. i will drive them only this year until i fix my 17" rims
i hope the z33 wheels will fit :/my sunset Z youtu.be/HVp6CFcrx2U
mammutMember- 80
I have spacers
I will Drive it with offset 5mmmy sunset Z youtu.be/HVp6CFcrx2U
-Strike-Senior Member- 1968
I bought new tires for my Z33 wheels. Here's what I run now;
235/40/18 F - 255/40/18 R
This below was taken from my build thread;
Factory: 225/45/18 Front - 25.9" inches diameter
.......... 245/45/18 Rear - 26.7" Diameter.
Option 1. 225/45/18 Front - 25.9" Diameter
........... 255/40/18 Rear - 26" Diameter
Option 2. 235/40/18 Front - 25.4" Diameter
I ran these wheels Without spacers for a while and the original tire size before I bought new tires. The only issue is the dust cap does not fit behind the wheel on the front. It's VERY close to the strut perch for sure without spacers, luckily when I bought my wheels, the tread was low on the tires.. new tread may have issues?
with my new tire size, which I went with Option 2, are still pretty close, and I have 25mm spacers on now.
mammutMember- 80
thank u very much for the answer =)-Strike-;337643 wrote: I bought new tires for my Z33 wheels. Here's what I run now;
this kind of answer i estimated
so it will be very close to the strut perch at rear and front ?
fender liner i will also put it out
front: 225/45 18x8 offset 30 + ??mm spacer (i won´t much spacer, how much do i need for not hiting the perch?)
back: 245/45 18x8 offset 30 + 25mm spacer ( everthing will be ok ? )
how u experience with the speedo at those tires ?my sunset Z youtu.be/HVp6CFcrx2U
Rear seems fine, front is pretty close to the perch, but no rubbing. Speedo reads slightly under on my car, so I have to be a little careful hah
mammutMember- 80
ok thank u =)
after weekend i will report with some picsmy sunset Z youtu.be/HVp6CFcrx2U
mammutMember- 80
so thank u very much for u info strike
i put my old wheels down to give them to a repair .. they are not round anymore :/
235/45/17 8,5x17 OFF 13
255/40/17 10x17 OFF 20
Borbet A rims .. they are very rare and light .. iw ill fix them and put it again on it
no i put my new z33 cobra wheels
225/45/18 8x18 Off 30 + 25mm spacer (=5 OFF)
245/45/18 8x18 Off 30 + 25mm spacer (=5 OFF)
at the front like u say it strike
without spacer it was rupping a littel bit at the shock.. but i was ennoth space to the strut perch .. with spacer i have no problems
BUT at the rear u dont have any problems with the wheels even without spacer´s at the inside .. but i think is very close to the edge with the spacer´s :/
i have to test if there ist scrapping or do u now if there is now problems with it ?my sunset Z youtu.be/HVp6CFcrx2U
New wheels look awesome on there. There shouldn't be any issues in the rear if they fit on there now nicely, I'd say run it for a little bit and check for any evidence of rubbing on anything. I think you'll be fine. Mine *looks* pretty close, but it's never rubbed on anything. About the only other thing you could do if you had issues with rubbing would be to reduce the sidewall height of the tire. But, I don't think you're going to have any issues. That style of wheel really suits the car well. I like.
mammutMember- 80
thank YOU strike
i will check it next weekend =)
the rims looks ok
.. sorry AZ i am from germany , i know my english is not very well
