link3591 link3592 link3593 link3594 link3595 link3596 link3597 link3598 link3599 link3600 link3601 link3602 link3603 link3604 link3605 link3606 link3607 link3608 link3609 link3610 link3611 link3612 link3613 link3614 link3615 link3616 link3617 link3618 link3619 link3620 link3621 link3622 link3623 link3624 link3625 link3626 link3627 link3628 link3629 link3630 link3631 link3632 link3633 link3634 link3635 link3636 link3637 link3638 link3639 link3640 link3641 link3642 link3643 link3644 link3645 link3646 link3647 link3648 link3649 link3650 link3651 link3652 link3653 link3654 link3655 link3656 link3657 link3658 link3659 link3660 link3661 link3662 link3663 link3664 link3665 link3666 link3667 link3668 link3669 link3670 link3671 link3672 link3673 link3674 link3675 link3676 link3677 link3678 link3679 link3680 link3681 link3682 link3683 link3684 link3685 link3686 link3687 link3688 link3689 link3690 link3691 link3692 link3693 link3694 link3695 link3696 link3697 link3698 link3699 link3700 link3701 link3702 link3703 link3704 link3705 link3706 link3707 link3708 link3709 link3710 link3711 link3712 link3713 link3714 link3715 link3716 link3717 link3718 link3719 link3720 link3721 link3722 link3723
Can I use these tires? Got them for free
  • BlazzinZ88
    BlazzinZ88
    • 132
    I wanted to get some wider tires to help with traction I have had a pair of 255/45/17 tires like new sitting around my house I got for free years ago just never had anything to use them on. I purchased a s14 a while back with z33 wheels and was thinking of using the wheels on the z. Will those tires fit ok on the 17x8 z33 wheels ok and if so will they then fit in the back of a 88 model with or without spacers? I don't want to waste money mounting them if they won't work. If they will fit but not with those wheels what width and offset would I be looking for?
    The saing goes you save the best for last which is why the letter Z was chosen as the last letter of the alphabet. It is also why it was chosen to represent the best car of the 80's.
    Respect the Z
  • G-E
    G-E
    Junior Member
    • 6320
    The tires will be slightly tall but nothing serious, and yes they should fit… z33 wheels will need spacers to look good
  • gorekill
    gorekill
    • 228
    When you say that you got them years ago, just how long ago?
    I would definitely inspect the tires for dry rot, especially in the sidewall and bead area. Take it from a tire guy, you don't want a tire that may blow out on you going on a car.
    Z31 owner as of 27/04/12!!! Sitting in my driveway as of 29/04/12!!!
    Let the madness begin!
  • 862sik
    862sik
    • 2159
    Id definitely inspect them. But when I ran my 17's with 20 offset 8'' wide with the 255/45/17 I was very close to the strut tube housing in the front. It never rubbed, but I couldn't even get my pinky in there.
    My Build Thread
  • G-E
    G-E
    Junior Member
    • 6320
    #5
    If you have stiff compound tires like V-Z rated, you only need a few mm of clearance, but keep in mind each tire model has a different side shape, one might rub and another might not in the same size
    The z33 wheels are +30ish offsets, if it was close with +20, you will need spacers
  • frostvectron
    frostvectron
    • 1044
    #6
    255 seems like a lot of tire to squeeze on an 8" wide wheel. It should fit, though.
    Justin
    1986 NA 2-seater
    Race Videos
    Build Thread
  • BlazzinZ88
    BlazzinZ88
    • 132
    #7
    I was looking them over they don't seem dry rotted they were kept in a cool kinda damp basement they need cleaned up but I don't notice any cracks
    Respect the Z
  • BlazzinZ88
    BlazzinZ88
    • 132
    #8
    Would a 1" spacer work ok with those My buddy has 2 of them I can have. What do you think would be a good size tire to pair with those on the front 7.5" wheels. And spacer size to use. I looked at the front wheels they have 215/45/17 on them with a lot of tread, maybe ill use them on the front and those 255/45/17 on the back I use the car for mostly drag racing and cruising around. Seem like a shame to take off new tires.
    Respect the Z
